Justin,
I notice you don't set an enabled=true|enabled=false flag anywhere here.
That's part of the Layer datatype and is a Boolean, I assume it can be
null? That's the difference.
Again, I don't understand what the meaning of enabled=NULL means...but
ok...
Ronak
-----Original Message-----
From: Justin Deoliveira [mailto:jdeolive@anonymised.com]
Sent: Thursday, June 11, 2009 2:12 PM
To: Patel, Ronak Avinash (US SSA)
Subject: Re: LayerGroup creation from REST Configruation
You don't need to specify the href, could be throwing stuff off, not
sure, here is an xml example that i know works:
curl -XPOST -d '<layerGroup> <name>spearfish</name> <layers> <layer>
<name>sfdem</name> </layer> <layer> <name>streams</name> </layer>
<layer> <name>roads</name> </layer> <layer> <name>restricted</name>
</layer> <layer> <name>archsites</name> </layer> <layer>
<name>bugsites</name> </layer> </layers> </layerGroup>' -H
'Content-type: text/xml'
http://localhost:8080/geoserver/rest/layergroups
Also, can you turn the logs up on your server to get the stack trace
(GEOSERVER_DEVELOPER_LOGGING), not sure where the error is.
Patel, Ronak Avinash (US SSA) wrote:
Justin,
If that's so, I get an HTTP 500 from Geoserver 1.7.3 when I perform
the
following HTTP query:
POST /geoserver/rest/layergroups HTTP/1.1
Authorization: Basic YWRtaW46Z2Vvc2VydmVy
Content-Type: application/json
User-Agent: Java/1.6.0_13
Host: localhost:8080
Accept: text/html, image/gif, image/jpeg, *; q=.2, */*; q=.2
Connection: keep-alive
Content-Length: 1081
{"layerGroup":{"layers":{"layer":[{"enabled":"true","href":"http://local
host:8080/geoserver/rest/layers/Arc_Sample.json","name":"Arc_Sample"},{"
enabled":"true","href":"http://localhost:8080/geoserver/rest/layers/Arc_
Sample.json","name":"Arc_Sample"},{"enabled":"true","href":"http://local
host:8080/geoserver/rest/layers/Pk50095.json","name":"Pk50095"},{"enable
d":"true","href":"http://localhost:8080/geoserver/rest/layers/Pk50095.js
on","name":"Pk50095"},{"enabled":"true","href":"http://localhost:8080/ge
oserver/rest/layers/mosaic.json","name":"mosaic"},{"enabled":"true","hre
f":"http://localhost:8080/geoserver/rest/layers/sfdem.json","name":"sfde
m"},{"enabled":"true","href":"http://localhost:8080/geoserver/rest/layer
s/Img_Sample.json","name":"Img_Sample"},{"enabled":"true","href":"http:/
/localhost:8080/geoserver/rest/layers/image_WGS84_1242678004681_1430.jso
n","name":"image_WGS84_1242678004681_1430"},{"enabled":"true","href":"ht
tp://localhost:8080/geoserver/rest/layers/image_WGS84_1242685755119_70.j
son","name":"image_WGS84_1242685755119_70"}]},"name":"ronak-test-group"}
HTTP/1.1 500 Internal Server Error
X-Powered-By: Servlet/2.5
Server: Sun GlassFish Enterprise Server v2.1
Content-Type: text/html; charset=iso-8859-1
Transfer-Encoding: chunked
Date: Thu, 11 Jun 2009 19:30:01 GMT
Connection: close5
:null
0From the Geoserver logs:
[#|2009-06-11T12:27:08.210-0700|INFO|sun-appserver2.1|javax.enterprise.s
ystem.stream.out|_ThreadID=21;_ThreadName=httpSSLWorkerThread-8080-4;|11
Jun 12:27:08 INFO [catalog.rest] - POST layer group ronak-test-group
Jun 12:27:08 ERROR [geoserver.rest] - :null
|#]Do I smell yet another bug inside Geoserver??
Sent: Thursday, June 11, 2009 1:01 PM
Subject: Re: LayerGroup creation from REST ConfigruationHi Ronak,
You have found yet another hole in the docs. I will try to update when
i
get a sec. But the quick answer is yes, only the name and the layers
are
necessary when posting a layer group. The bounding box is the spatial
extent of the layer group. You can specify a bounding box, but it is
not
necessary, it will be calculated automatically if not specified.
Usually
the only reason to specify it would be if perhaps one of the layers in
the group is quite big and you want the group to be constrained to a
smaller spatial extent. Like the tiger-ny layer group that comes with
vanilla geoserver configuration.The styles are optional, if you don't specify them then the default
style for each layer will be used. If you do specify them, then you
specify a style for each layer specified.Hope that helps.
-Justin
Justin,
I was looking at the LayerGroup REST API Documentation and I see that
it
has a POST API Document:
http://docs.geoserver.org/1.7.4/user/extensions/rest/rest-config-api.htm
l#id8
However, it does not list what are the required parameters for a POST
for a LayerGroup.
I assume I have to pass the name and the list of Layers. Do I need to
specify a bounding box? What is that the bounding box of? How can I
compile that bounding box?What are the Styles? Do I have to specify those as well?
Ronak
Justin Deoliveira
OpenGeo - http://opengeo.org
