[Geoserver-users] LayerGroup default style
Is it possible to name LayerGroup's "global" style somehow? There are
applications (e.g. MapGuide Server) that require style name, and if not
explicitly specified they query for "default" (thus "style=default" in URL
params). Once GeoServer receives a query for LayerGroup's style named
"default" it throws "ERROR [geoserver.ows] -
org.geoserver.platform.ServiceException: No such style: default" exception.
With kindest regards,
Maksim Sestic
View this message in context: http://osgeo-org.1560.x6.nabble.com/LayerGroup-default-style-tp5060628.html
Hi Maksim,
Several thoughts:
  1. MapGuide Server’s behaviour seems odd. The WMS spec is very clear: if you ask for a style that doesn’t exist then an exception shall be raised. So filling in “default” seems odd as there is no guarantee that a “default” will exist. Blank is the logical choice - the spec is clear:
    “A client may request the default Style using a null value (as in “STYLES=”).”
    So even though it’s a “may” not a “shall”, MapGuide Server seems to be doing it wrong.
  2. Can’t you use the “SLD” parameter to point to a “default” SLD of your own choosing?
  3. I don’t think a LayerGroup can have a single style, although for scenarios like this I imagine it should be possible to, but then, how do you create a single SLD that encompasses all of the different components?
Jonathan
On 17 June 2013 16:25, Maksim Sestic <max@…5667…> wrote:
Is it possible to name LayerGroup’s “global” style somehow? There are
explicitly specified they query for “default” (thus “style=default” in URL
params). Once GeoServer receives a query for LayerGroup’s style named
“default” it throws “ERROR [geoserver.ows] -
org.geoserver.platform.ServiceException: No such style: default” exception.
Maksim Sestic
This SF.net email is sponsored by Windows:
Build for Windows Store.
http://p.sf.net/sfu/windows-dev2dev
Geoserver-users mailing list
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
Hi Jonathan,
Yes, I agree, MapGuide is missing a point with “styles=default”. Alas, this happens on both open source and commercial MG platforms I’m dealing with. This actually has to do with FDO provider for WMS (http://fdo.osgeo.org/) under the hood. I’m currently trying to figure out whether it’s possible to override such beahviour using additional WMS parameters, but it’s less likely.
With regards to LayerGroup style – I guess it should have one in case Geoserver publishes it as a Single layer (?)… although a “shallow” one since setting SLD at root level should override containing layer styles.
Maksim Sestic
From: Jonathan Moules [mailto:jonathanmoules@anonymised.com]
Sent: Friday, June 21, 2013 11:39
To: Maksim Sestic
Subject: Re: [Geoserver-users] LayerGroup default style
Hi Maksim,
Several thoughts:
  1. Can’t you use the “SLD” parameter to point to a “default” SLD of your own choosing?
  2. I don’t think a LayerGroup can have a single style, although for scenarios like this I imagine it should be possible to, but then, how do you create a single SLD that encompasses all of the different components?
Jonathan
Maksim Sestic
Hi Maksim
That is something that I was scratching my head about reading the spec. It clearly says:
“Comma-separated list of one rendering style per requested layer.”
To the end-user of the WMS, a LayerGroup is actually single layer, so in theory they should be able to specify a style when requesting it. However, I’ve just tested it and the style is completely ignored.
Strictly speaking this seems contrary to what the WMS spec says should happen.
But for bonus fun, as you’ve discovered, if the style you specify doesn’t exist, GeoServer will give you an exception. So LayerGroups seem to be the worst of both worlds:
  • Include a non-existent style and it will error.
  • Include a valid style and it will be ignored.
To me the solution is actually for LayerGroups to completely ignore the style parameter, even if the given value is invalid. They’re already breaking the spec, why not go one step further. :slight_smile:
Of course, the solution for you is to fill in anything you want as the style, just make sure it exists. “line” “point” etc as the undeleatable GeoServer defaults would be good choices to use.
Jonathan
On 21 June 2013 11:21, Maksim Sestic <max@anonymised.com> wrote:
Hi Jonathan,
Maksim Sestic
To: Maksim Sestic
Hi Maksim,
Several thoughts:
Jonathan
Maksim Sestic
Hi Jonathan,
My thoughts exactly.
Maksim Sestic
Sent: Friday, June 21, 2013 13:59
To: Maksim Sestic
Hi Maksim
Jonathan
Hi Jonathan,
Maksim Sestic
To: Maksim Sestic
Hi Maksim,
Several thoughts:
Jonathan
Maksim Sestic
On 21 June 2013 12:59, Jonathan Moules
<jonathanmoules@anonymised.com>wrote:
Hi Maksim
Geoserver publishes it as a Single layer (?)... although a "shallow" one
clearly says:
"Comma-separated list of one rendering style per requested layer."
I've just tested it and the *style is completely ignored.*
happen.
This would only be true if the capabilities document listed a style for the
layer which GeoServer doesn't for layer groups (or at least for mine).
Ian
You can’t ask for styles that are not listed in the capabilities document against that layer.
Ian
On 21 June 2013 13:47, Maksim Sestic <max@anonymised.com> wrote:
Hi Jonathan,
Maksim Sestic
To: Maksim Sestic
Hi Maksim
Jonathan
Hi Jonathan,
Maksim Sestic
To: Maksim Sestic
Cc: geoserver-users@anonymised.comurceforge.net
Hi Maksim,
Several thoughts:
Jonathan
Maksim Sestic
Ian Turton
In which case it’s breaching this part of the spec:
A server shall throw an exception (code=StyleNotDefined) if an unadvertised Style is requested.
Because you can request an unadvertised style and no exception is thrown. You only get the exception if you request a non-existent style.
Personally I prefer it the way it currently is - able to use any style that exists, even if they’re not in GetCapabilities.
Hi Jonathan,
Maksim Sestic
To: Maksim Sestic
Hi Maksim
Jonathan
Hi Jonathan,
Maksim Sestic
To: Maksim Sestic
Hi Maksim,
Several thoughts:
Jonathan
Maksim Sestic
Ian Turton
Hi Ian,
Yes, ISO 19115 states following about GetCapabilities and resulting WMS layer style clause:
Style
Required to have name/title elements, if only one style it is default
Optional
But it’s not about resulting style info (as it’s Optional anyways), it’s rather how Geoserver handles default and/or non-existing layer requests under the hood.
Maksim Sestic
Sent: Friday, June 21, 2013 15:02
To: Maksim Sestic
Cc: Jonathan Moules; geoserver-users
Ian
Hi Jonathan,
Maksim Sestic
To: Maksim Sestic
Hi Maksim
Jonathan
Hi Jonathan,
Maksim Sestic
To: Maksim Sestic
Hi Maksim,
Several thoughts:
Jonathan
Maksim Sestic
Ian Turton
On 21 June 2013 14:04, Jonathan Moules
In which case it's breaching this part of the spec:
that exists, even if they're not in GetCapabilities.
If you ask for a style that is not listed in the capabilities then it may
not match the layer you are using and could throw an error anyway.
Ian
On 21 June 2013 14:02, Ian Turton <ijturton@anonymised.com> wrote:
You can't ask for styles that are not listed in the capabilities document
against that layer.
Ian
Hi Jonathan,****
I've just tested it and the *style is completely ignored.*****
happen.****
My thoughts exactly.****
Regards,****
Maksim Sestic****
*From:* Jonathan Moules [mailto:jonathanmoules@anonymised.com]
*Sent:* Friday, June 21, 2013 13:59
*To:* Maksim Sestic
*Cc:* geoserver-users@lists.sourceforge.net
*Subject:* Re: [Geoserver-users] LayerGroup default style
Hi Maksim ****
It clearly says:****
"Comma-separated list of one rendering style per requested layer."****
happen.****
But for bonus fun, as you've discovered, if the style you specify
doesn't exist, GeoServer will give you an exception. So LayerGroups seem to
be the worst of both worlds:****
- Include a non-existent style and it will error.****
- Include a valid style and it will be ignored.****
style parameter, even if the given value is invalid. They're already
breaking the spec, why not go one step further. :-)****
style, just make sure it exists. "line" "point" etc as the undeleatable
GeoServer defaults would be good choices to use.****
Regards,****
Jonathan****
On 21 June 2013 11:21, Maksim Sestic <max@anonymised.com> wrote:****
Hi Jonathan,****
Yes, I agree, MapGuide is missing a point with "styles=default". Alas,
this happens on both open source and commercial MG platforms I'm dealing
http://fdo.osgeo.org/) under the hood. I'm currently trying to figure
out whether it's possible to override such beahviour using additional WMS
parameters, but it's less likely.****
Regards,****
Maksim Sestic****
*Sent:* Friday, June 21, 2013 11:39
*To:* Maksim Sestic
*Subject:* Re: [Geoserver-users] LayerGroup default style****
Hi Maksim,****
Several thoughts:****
1) MapGuide Server's behaviour seems odd. The WMS spec is very clear: if
you ask for a style that doesn't exist then an exception *shall* be raised.
So filling in "default" seems odd as there is no guarantee that a "default"
will exist. Blank is the logical choice - the spec is clear:****
"A client *may* request the default Style using a null value (as in
"STYLES=")."****
So even though it's a "may" not a "shall", MapGuide Server seems to be
doing it wrong.****
2) Can't you use the "SLD" parameter to point to a "default" SLD of your
own choosing?****
3) I don't think a LayerGroup can have a single style, although for
Regards,****
Jonathan****
On 17 June 2013 16:25, Maksim Sestic <max@anonymised.com> wrote:****
URL
exception.
Maksim Sestic
Best Open Source Mac Front-Ends 2024
geoserver-users List Signup and Options****
and/or monitoring in accordance with relevant legislation.****
Ian Turton
Ian Turton
Hi Ian, Jonathan,
Few interesting details from OGC 06-042 WMS Implementation Specs / v1.3.0:
"Zero or more Styles may be advertised for a Layer or collection of layers using elements (…) If only a single style is available, that style is known as the “default” style and
need not be advertised by the server."
Also:
“(…) Style declarations are inherited by child Layers. A child shall not redefine a Style with the same Name as one inherited from a parent. A child may define a new Style with a new Name that is not available for the parent Layer.”
Maksim Sestic
Sent: Friday, June 21, 2013 15:15
To: Jonathan Moules
Cc: Maksim Sestic; geoserver-users
If you ask for a style that is not listed in the capabilities then it may not match the layer you are using and could throw an error anyway.
Ian
Ian
Hi Jonathan,
Maksim Sestic
To: Maksim Sestic
Hi Maksim
Jonathan
Hi Jonathan,
Maksim Sestic
To: Maksim Sestic
Hi Maksim,
Several thoughts:
Jonathan
Maksim Sestic
Ian Turton
Ian Turton
