Hi, I was change my version 1.6.5 to 1.7.3 of geoserver for use the layers.properties because I have a webservices private, only is 1 shape, the I was modify my file users.properties, and I created a new user and a new role. And the file layers.properties I was add the new lines, then I was probe this service with gvsig 1.1.2 and arcgis 9.2 and never watch this server, What do I need do for use this server or send my user and pass for see this server??
could you helpme??
Thanks
pd. add the text from my files properties
layers.properties
..r=*
..w=NO_ONE
sf..r=ROLE_PRUEBA
sf..w=ROLE_PRUEBA
users.properties
prueba1=prueba,ROLE_PRUEBA
Arturo Juárez Lima
“*Cuando quieres realmente una cosa todo el Universo conspira para ayudarte a conseguirla”-*Paulo Coelho
Hi Arturo,
GeoServer uses basic authentication so the client or whatever is sending requests needs to set the appropriate http "Authorization" header which follows the form: Basic + <base64 encoded username + pass>. So something like:
setHeader( "Authorization", "Basic " + Base64.encode(username+":"+password) )
-Justin
Arturo Juàrez wrote:
Hi, I was change my version 1.6.5 to 1.7.3 of geoserver for use the layers.properties because I have a webservices private, only is 1 shape, the I was modify my file /*users.properties, */and I created a new user and a new role. And the file /*layers.properties*/ I was add the new lines, then I was probe this service with gvsig 1.1.2 and arcgis 9.2 and never watch this server, What do I need do for use this server or send my user and pass for see this server??
could you helpme??
Thanks
*layers.properties
**.*.r=*
*.*.w=NO_ONE
sf.*.r=ROLE_PRUEBA
sf.*.w=ROLE_PRUEBA
*users.properties
*prueba1=prueba,ROLE_PRUEBA
/*Arturo Juárez Lima*/
“/Cuando quieres realmente una cosa todo el Universo conspira para ayudarte a conseguirla”-//Paulo Coelho/
Geoserver-users mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
Hi Justin and thanks for your answer, I was probe with my web of geoserver and when I was write the user prueba1 really is working, but when I am probe with the arcgis or gvsig or udig for add the webservice , I don’t find the part where write the user prueba1 for showme the service sf., I can see all the others but the shape sf. not.
if can use of this form (with user and pass) a webservice??
Justin Deoliveira escribió:
Arturo Juárez Lima
Hi Arturo,
GeoServer uses basic authentication so the client or whatever is sending requests needs to set the appropriate http “Authorization” header which follows the form: Basic + <base64 encoded username + pass>. So something like:
setHeader( “Authorization”, “Basic " + Base64.encode(username+”:"+password) )
-Justin
Hi, I was change my version 1.6.5 to 1.7.3 of geoserver for use the layers.properties because I have a webservices private, only is 1 shape, the I was modify my file /*users.properties, */and I created a new user and a new role. And the file /layers.properties/ I was add the new lines, then I was probe this service with gvsig 1.1.2 and arcgis 9.2 and never watch this server, What do I need do for use this server or send my user and pass for see this server??
could you helpme??
Thanks
layers.properties
**..r=*
..w=NO_ONE
sf..r=ROLE_PRUEBA
sf..w=ROLE_PRUEBA
*users.properties
/Arturo Juárez Lima/
Arturo Juàrez ha scritto:
Hi Justin and thanks for your answer, I was probe with my web of geoserver and when I was write the user /prueba1/ really is working, but when I am probe with the arcgis or gvsig or udig for add the webservice , I don't find the part where write the user /prueba1 /for showme the service sf.*, I can see all the others but the shape sf.* not.
That's because GeoServer defaults to HIDE mode, whilst you
want CHALLENGE mode. See the security subsystem guide:
http://geoserver.org/display/GEOSDOC/2.6+Security+subsystem,
look for "mode=HIDE|CHALLENGE|MIXED".
Andrea Aime
I've been using the OGR2OGR WFS extension with good success. Could a similar thing be done for WCS and GDALTranslate? This would open up a large number of raster output formats, plus ending up as a Zip file for easier download.
Thanks!
Roger
Yep, it could be done, seems like a good idea actually. Can you open
a feature request on jira.codehaus.org?
You can have a look at the OGR2OGR extension sources here:
http://svn.codehaus.org/geoserver/branches/1.7.x/src/extension/ogr/
The code needed would be somewhat similar, thought plugging into WCS output format is harder (but if you want to try, I can open a proper
extension point for WCS output formats).
Andrea Aime
Andrea,
It has been added to Jira. Seems like a lot of gain for not much pain.
Not sure I can do it very easily though, but I'll be glad to test it.
Roger
Sent: Thursday, March 26, 2009 1:00 PM
To: "Roger Bedell" <roger@anonymised.com>
Cc: <geoserver-users@lists.sourceforge.net>
Subject: Re: [Geoserver-users] WCS GdalTranslate Extension?
Andrea Aime
Andrea,
Roger
Andrea Aime
Thanks Andrea, I was prube with UDIG and work with out problem, but in gvsig was send me error and never was ask me to user.
are you know the reason of why don’t ask me the user??
Thanks again.
Andrea Aime escribió:
Arturo Juárez Lima
Hi Justin and thanks for your answer, I was probe with my web of geoserver and when I was write the user /prueba1/ really is working, but when I am probe with the arcgis or gvsig or udig for add the webservice , I don’t find the part where write the user /prueba1 /for showme the service sf., I can see all the others but the shape sf. not.
That’s because GeoServer defaults to HIDE mode, whilst you
look for “mode=HIDE|CHALLENGE|MIXED”.
are you know the reason of why don't ask me the user??
I guess gvSig cannot handle HTTP basic authentication then.
uDig, Google Earth work fine, afaik also MapInfo and
ArcGis do.
Andrea Aime
ok, I this moment I’m finish my probe with arcgis 9.2 but neither display the shape, only showme the name from the shape, when I check on the shape don’t display nothing
Arturo Juárez Lima
ArcGis do.
ArcGis do.
OpenJUMP supports HTTP basic authentication, also over https (nightly build only, until version 1.3 is published). There is no dialog for credentials, though, but they must be given in WMS connection URL. Maybe gvSIG is using the same method.
-Jukka Rahkonen-
