[Geoserver-users] LDAP authentication with group/role discovery still seems broken
Hi everyone,
I am struggling with LDAP as GeoServer (2.24.2) does not manage to pick up groups/roles from it.
I did post on https://gis.stackexchange.com/questions/477658/geoserver-does-not-find-ldap-groups-of-user with no solution so far.
- LDAP users can log in.
- A LDAP User/Group Service does discover the users and groups.
- A LDAP Role Service does discover/create the roles (ROLE_GROUPNAME).
There are several older inconclusive threads about probably the same issue, seemingly introduced after 2.15.2:
- https://sourceforge.net/p/geoserver/mailman/geoserver-users/thread/a799bca3-0741-5caf-1db1-ca017b35a78e@anonymised.com/
- https://sourceforge.net/p/geoserver/mailman/geoserver-users/thread/d2bb87fd-7a89-0aa5-7a3f-e975aaeba967@anonymised.com/
- https://sourceforge.net/p/geoserver/mailman/geoserver-users/thread/SJ0PR08MB6800C0E997D3CBD049D22B8ED71F9@anonymised.com/
https://osgeo-org.atlassian.net/browse/GEOS-10452 was closed with a commit that did not actually really related to the ticket.
The ticket is about role discovery for a user that is being authenticated. The commit was about the Role Service, a component that makes existing groups/roles visible in GeoServer. From all what I have found so far, the Role Service is *not* related to the role discovery during authentication.
So I think that ticket was wrongly closed.
I have used the very same LDAP user, query etc in a Python script with success so the filters and whatnot seem correct.
I have tried using a 2.15.2 geoserver.war without success (but maybe using the same GeoServer data directory led to issues).
I have tried using the existing 2.24.2 with gs-sec-ldap-2.15.2.jar and gs-web-sec-ldap-2.15.2.jar as suggested in https://sourceforge.net/p/geoserver/mailman/message/37633270/ without success.
I have tried using the existing 2.24.2 with gs-sec-ldap-2.15.2.jar and gs-web-sec-ldap-2.15.2.jar PLUS (spring-ldap-core-2.0.2.RELEASE.jar and spring-security-ldap-4.0.4.RELEASE.jar) or (spring-ldap-core-2.3.2.RELEASE.jar and spring-security-ldap-5.1.5.RELEASE.jar) without success.
I have tried using the existing 2.24.2 with (spring-ldap-core-2.0.2.RELEASE.jar and spring-security-ldap-4.0.4.RELEASE.jar) or (spring-ldap-core-2.3.2.RELEASE.jar and spring-security-ldap-5.1.5.RELEASE.jar) without success.
I compiled GeoServer 2.25 using Maven and added some more logging in BindingLdapAuthoritiesPopulator.java#getGroupMembershipRoles to see the formattedFilter before and after the escaping, and also inspect the other variables.
They all look fine.
Strangely it seems to work with the acme-ldap.jar from https://docs.geoserver.org/main/en/user/security/tutorials/ldap/index.html
bob gets ROLE_USER with it.
The group/role discovery seems to work differently with that setup though. There are no "security.ldap" lines in the log when using it, instead all I see is:
28 Feb 13:24:15 DEBUG [filter.GeoServerUserNamePasswordAuthenticationFilter$1] - Set SecurityContextHolder to UsernamePasswordAuthenticationToken [Principal=LdapUserDetailsImpl [Dn=uid=bob,ou=people,dc=acme,dc=org; Username=bob; Password=[PROTECTED]; Enabled=true; AccountNonExpired=true; CredentialsNonExpired=true; AccountNonLocked=true; Granted Authorities=[ROLE_USER]], Credentials=[PROTECTED], Authenticated=true, Details=GeoServerWebAuthenticationDetails [RemoteIpAddress=127.0.0.1, SessionId=A02D2978C7562773FF7F842FCF3B3E99], Granted Authorities=[ROLE_AUTHENTICATED, ROLE_USER]]
One small difference might be that this uses ou=groups, not cn=groups, but I have no clue if that is something meaningful or just text.
Is anyone using a standard GeoServer 2.24 with working role discovery via LDAP?
Could this be something in Spring?
Cheers, Hannes
Hi Hannes,
I confirm that LDAP works properly in Geoserver 2.22. I have not tried
with 2.24 for the moment.
Maybe you can try 2.22 to see if it is really a problem in Geoserver
version or it is some other problem related with your settings or your
environment.
César
On Wed, 28 Feb 2024 at 14:50, <hk.ihatemailinglists@anonymised.com> wrote:
Hi everyone,
They all look fine.
Cheers, Hannes
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
- Earning your support instead of buying it, but Ian Turton: http://www.ianturton.com/talks/foss4g.html#/
- The GeoServer user list posting guidelines: http://geoserver.org/comm/userlist-guidelines.html
If you want to request a feature or an improvement, also see this: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
   César Martínez Izquierdo
   GIS developer
   SCOLAB: http://www.scolab.es
Hello everyone,
actually, this seems to be broken for a long time. I'm runnig GS version 2.22.2.
I was researching on this issue several years ago and, as far as I remember, the problem was that the actual LDAP query that gathers the newly authenticated user's roles is not correctly formed/encoded etc. I do no longer know the extact problem, but the query used some escaping (where it shouldn't) or did not escape some things (it better should have escaped).
Use a network analyzer (e.g. WireShark on Windows or tcpdump on Linux) and track the LDAP queries issued by GeoServer while logging in a user. Likley you should temporarily switch to non-ssl LDAP (use ldap:// and not ldaps://) in order to make packet analyzing easier.
Likely the "get this user's roles" query looks odd (in contrast to the other LDAP queries). That could be a starting point for finding the problem in GeoServer's LDAP libraries.
Carsten
Am 28.02.2024 um 14:33 schrieb hk.ihatemailinglists@anonymised.com:
Hi everyone,
They all look fine.
Cheers, Hannes
Thanks Carsten!
The escaping issue was probably https://github.com/geoserver/geoserver/pull/6189 (the Spring framework(?) changed so GeoServer had to adapt).
We do not have any commas or other special characters in our values though, both {0} and {1} are simple alphanumeric+"=" lowercase strings like "foo" or "uid=alice,cn=admins,cn=users,dc=foo,dc=bar,dc=baz,dc=com" (comma-delimited, no commas in the actual "values").
And I looked at the strings before and after escaping, they were always the same for me.
I have to take back that https://osgeo-org.atlassian.net/browse/GEOS-10452 was closed with a not-really-related PR (the #6189). The PR actually is titled in a misleading way as its changes to affect not only Role Services (and User/Group services) but the lookup during authentication as well.
Great idea about the logging. I won't be able to MITM the connection or switch the remote LDAP to non-ssl but maybe I can get them to check logs on the LDAP server end.
Cheers, Hannes
Carsten Klein schrieb am 28.02.2024 15:17 (GMT +01:00):
Hello everyone,
2.22.2.
have escaped).
Carsten
Hi everyone,
I did post on
variables.
They all look fine.
is:
LDAP?
Cheers, Hannes
list:
Thank you César!
If it works for you, that is great news.
Thank you for sharing censored information with me in private. I spotted a small difference:
In your (working) case there is "ou=users" and "ou=groups" while in my case we have "cn=users" and "cn=groups".
The acme-ldap.jar from https://docs.geoserver.org/stable/en/user/security/tutorials/ldap/index.html#ldap-server-setup also uses "ou=groups" and worked in my tests.
I will try to recompile acme-ldap.jar and changing its structure to "cn=groups" to see if that still works.
Maybe Spring (or GeoServer in some hidden place) is really adamant on some specific CN structure? I looked around and the "group search base" always looks completely configurable even if it usually uses a "ou=..." thing in examples.
- https://docs.spring.io/spring-security/site/docs/4.0.x/reference/html/ldap.html#loading-authorities (4)
- https://docs.spring.io/spring-security/site/docs/4.0.x/apidocs/org/springframework/security/ldap/userdetails/DefaultLdapAuthoritiesPopulator.html (4)
- https://docs.spring.io/spring-security/site/docs/6.1.6-SNAPSHOT/api/org/springframework/security/ldap/userdetails/DefaultLdapAuthoritiesPopulator.html (6, identical to 4)
Cheers, Hannes
César Martínez Izquierdo schrieb am 28.02.2024 15:03 (GMT +01:00):
Hi Hannes,
environment.
César
Hi everyone,
I did post on
variables.
They all look fine.
is:
LDAP?
Cheers, Hannes
list:
   GIS developer
list:
"I dont know what I am doing"-Chapter 23:
# "ou=" vs "cn="? Hardcoded "admin" lookup?
Because the acme-ldap.jar WORKS with role discovery (bill gets ROLE_ADMIN):
- I have changed the acme-ldap.jar to use "cn=users" and "cn=groups" instead of "ou=users" and "ou=groups". Works well just like before.
- I have renamed "cn=users" to "cn=users1" and "cn=admins" to "cn=admins2", the user bill now gets Granted Authorities=[ROLE_AUTHENTICATED, ROLE_ADMIN2]`.
So there is no hardcoded logic to look for "ou=" instead of "cn=" somewhere and neither something hardcoded on a specific "admin" group name.
# ACME structure vs our structure
Unfortunately I did not manage to reconstruct a minimal example of our structure using the code of acme-ldap.jar because it seems like our LDAP uses many "auxiliary" objectClass things and I am too stupid to add those in the code. :\ Otherwise I would gladly provide a acme-ldap.jar that reproduces our structure for debugging
## Our structure, as shown in Apache Directory Studio
- dc=argh,dc=org
  - cn=groups
    - cn=services
      - cn=thingiwantasrole with these attributes (and more):
        - objectClass=posixGroup
        - objectClas=univentionGroup
        - objectClass=...
        - memberUid=foo
        - memberUid=bar
        - uniqueMember=uid=foo,cn=...
        - uniqueMember=uid=bar,cn=...
    - cn=...
  - cn=users
    - cn=admins
      - uid=foo with these attributes (and more):
      nd more):
        - objectClass=organizationalPerson
        - objectClass=person
        - objectClass=posixAccount
        - objectClass=top
        - objectClass=univentionObject
        - objectClass=...
        - cn=Foo Oof
        - uid=foo
        - displayName=Foo Off
      - uid=bar
      - uid=...
  - cn=...
## Default acme-ldap.jar structure, as shown in Apache Directory Studio
- dc=acme,dc=org
  - ou=groups (objectClass=organizationalRole, objectClass=top)
    - cn=admin with these attributes:
      - objectClass=groupOfNames
      - objectClass=top
      - cn=admin
      - member=uid=bill,ou=people,dc=acme,dc=org
    - cn=user
      - objectClass=top
      - cn=user
      - member=uid=alice,ou=people,dc=acme,dc=org
      - member=uid=bob,ou=people,dc=acme,dc=org
  - ou=people
    - uid=alice with these attributes:
      - objectClass=inetOrgPerson
      - objectClass=top
      - cn=Alice
      - sn=Alice
      - displayName=Alice
      - givenName=Alice
      - uid=alice
      - userPassword=Plain text password
    - uid=bill
    - uid=bob
## Differences
- acme has all users in one directory, we have subdirectories
- acme has the groups directly below groups ("cn=admin,ou=groups"), we have an additional directory subtree ("cn=thingiwantasrole,cn=services,cn=groups")
- acme uses "member" as attribute name, we use "memberUid" or "uniqueMember" (one is the UID, the other the full DN(?) of the user)
- acme's groups are "objectClass=groupOfNames", while ours have various different attributes like "posixGroup" and "univentionGroup"
# More
- The `DEBUG [security.ldap] - Roles from search: ...` line does not appear with acme, yet bill gets ROLE_ADMIN! This seems like a great hint but I have not managed to find anything useful by tracing back the functions called before that.
- Using python-ldap I can use the same code and logic to discover the groups with the acme as well as our LDAP:
import ldap  # python-ldap, https://www.python-ldap.org
server = "ldap://localhost:10389/"
dn = "uid=bob,ou=people,dc=acme,dc=org"
password = "secret"
connection = ldap.initialize(server)
connection.simple_bind_s(dn, password)
result = connection.search_s(
  base="ou=groups,dc=acme,dc=org",
  scope=ldap.SCOPE_SUBTREE,
  filterstr="(&(objectClass=groupOfNames)(member=uid=bill,ou=people,dc=acme,dc=org))",
  attrlist=["cn"],
print([r[1] for r in result])
gives me `[{'cn': [b'admin']}]`.
Using our server host with
- dn = "uid=foo,cn=admins,cn=users,dc=argh,dc=org"
- base="cn=groups,dc=argh,dc=org",
- filterstr="(&(objectClass=univentionGroup)(uniqueMember=uid=foo,cn=admins,cn=users,dc=argh,dc=org))",
gives me `[{'cn': [b'thingiwantasrole']}, {'cn': [b'anothergroup']}]`.
Thanks for reading! I hope the mailing list did not ruin the formatting too much.
Maybe someone has more or better ideas how to continue the search :slight_smile:
Cheers, Hannes
hk.ihatemailinglists@anonymised.com schrieb am 29.02.2024 10:49 (GMT +01:00):
Thank you César!
small difference:
(4)
(4)
(6, identical to 4)
Cheers, Hannes
I’m sure that I made LDAP roles work with a more recent version of GeoServer at my previous job (unfortunately it’s behind a firewall so I can’t check) -
My LDAPUserGroupService config contained:
ou=groups,dc=galbraith,dc=co,dc=uk
cn
(objectClass=groupOfUniqueNames)
(uniqueMember=uid={0},ou=users,dc=galbraith,dc=co,dc=uk)
uniqueMember
uid
(objectClass=inetOrgPerson)
false
false
10
(uniqueMember={0})
true
ROLE_
true
and my LDAPRoleServiceConfig
included
cn=*
false
false
10
(member={0})
true
ROLE_ADMINS
ROLE_ADMINS
ROLE_
true
My notes also include in bold You must make the new role service the active one by changing the drop down on the security->settings` page https://docs.geoserver.org/latest/en/user/security/webadmin/settings.html#active-role-service
I can highly recommend using a cli tool like ldapsearch to test out your queries to see what they should be, which is how I got to (uniqueMember=cn={0},ou=users,dc=galbraith,dc=co,dc=uk) for my group member search
Ian
Ian Turton
Hannes,
I see the group search filter you use is very complex compared to the
one Ian or I use.
Maybe your problem is there?
Best regards,
César Martínez
On Thu, 29 Feb 2024 at 16:03, Ian Turton <ijturton@anonymised.com> wrote:
I'm sure that I made LDAP roles work with a more recent version of GeoServer at my previous job (unfortunately it's behind a firewall so I can't check) -
<groupSearchBase>ou=groups,dc=galbraith,dc=co,dc=uk</groupSearchBase>
  <groupNameAttribute>cn</groupNameAttribute>
  <allGroupsSearchFilter>(objectClass=groupOfUniqueNames)</allGroupsSearchFilter>
  <groupSearchFilter>(uniqueMember=uid={0},ou=users,dc=galbraith,dc=co,dc=uk)</groupSearchFilter>
  <groupMembershipAttribute>uniqueMember</groupMembershipAttribute>
  <userSearchBase>ou=users,dc=galbraith,dc=co,dc=uk</userSearchBase>
  <userNameAttribute>uid</userNameAttribute>
  <allUsersSearchFilter>(objectClass=inetOrgPerson)</allUsersSearchFilter>
  <useTLS>false</useTLS>
  <useNestedParentGroups>false</useNestedParentGroups>
  <maxGroupSearchLevel>10</maxGroupSearchLevel>
  <nestedGroupSearchFilter>(uniqueMember={0})</nestedGroupSearchFilter>
  <bindBeforeGroupSearch>true</bindBeforeGroupSearch>
  <rolePrefix>ROLE_</rolePrefix>
  <convertToUpperCase>true</convertToUpperCase>
included
  <allGroupsSearchFilter>cn=*</allGroupsSearchFilter>
  <groupSearchFilter>uniqueMember=uid={0},ou=users,dc=galbraith,dc=co,dc=uk</groupSearchFilter>
  <nestedGroupSearchFilter>(member={0})</nestedGroupSearchFilter>
  <adminGroup>ROLE_ADMINS</adminGroup>
  <groupAdminGroup>ROLE_ADMINS</groupAdminGroup>
My notes also include in bold `You must make the new role service the active one by changing the drop down on the `security->settings` page https://docs.geoserver.org/latest/en/user/security/webadmin/settings.html#active-role-service
I can highly recommend using a cli tool like ldapsearch to test out your queries to see what they should be, which is how I got to `(uniqueMember=cn={0},ou=users,dc=galbraith,dc=co,dc=uk)` for my group member search
Ian
Ian Turton
   GIS developer
Ian, thank you so much! Your boldness saved the day/week/month :slight_smile:
Ian Turton schrieb am 29.02.2024 16:00 (GMT +01:00):
This was it!
Interestingly the log still says "[security.ldap] - Roles from search: " but my test user DOES get its roles assigned properly now using our LDAP server:
01 Mar 08:29:05 DEBUG [security.ldap] - Getting authorities for user uid=foo,cn=admins,cn=users,dc=example,dc=com
01 Mar 08:29:05 DEBUG [security.ldap] - Searching for roles for user 'foo', DN = 'uid=foo,cn=admins,cn=users,dc=example,dc=com', with filter (&(objectClass=univentionGroup)(memberUid={1})) in search base 'cn=services,cn=groups,dc=example,dc=com'
01 Mar 08:29:05 DEBUG [security.ldap] - Roles from search:
01 Mar 08:29:05 DEBUG [ldap.LDAPSecurityProvider$1] - Authenticated user
01 Mar 08:29:05 DEBUG [filter.GeoServerUserNamePasswordAuthenticationFilter$1] - Set SecurityContextHolder to UsernamePasswordAuthenticationToken [Principal=LdapUserDetailsImpl [Dn=uid=foo,cn=admins,cn=users,dc=example,dc=com; Username=foo; Password=[PROTECTED]; Enabled=true; AccountNonExpired=true; CredentialsNonExpired=true; AccountNonLocked=true; Granted Authorities=], Credentials=[PROTECTED], Authenticated=true, Details=GeoServerWebAuthenticationDetails [RemoteIpAddress=127.0.0.1, SessionId=123123123], Granted Authorities=[ROLE_AUTHENTICATED, ROLE_GEOSERVER_GLOBAL_ADMINS, ROLE_BEWARE_OF_THE_LEOPARD]]
Phew!
This leaves me confused though.
- Are there two ways of group/role discovery for LDAP users, one in the Authentication Provider and one with a Role Service? What is the difference? Are they completely different things?
- From the logs and behaviour it seems like the three "[security.ldap]" lines come from the Authentication Provider while the Role Service discovers them silently? Why does one discovery log something and the other doesn't?
I'll update https://gis.stackexchange.com/questions/477658/geoserver-does-not-find-ldap-groups-of-user momentarily, including the minimal configuration I ended up with. There is better formatting and higher search engine discovery on that site so I hope you don't mind if I switch from the mailing list.
Cheers, Hannes
PS: Future reader, once you switch the Role Service your GeoServer user "admin" won't become a GeoServer admin anymore. Make sure you have access to the "root" user's master password or that your LDAP setup includes a user that will become GeoServer admin!
As I said I updated the manual to try to make this clearer, if you can think of anything else that could be added please do edit it too.
Ian
This was it!
Interestingly the log still says “[security.ldap] - Roles from search: ” but my test user DOES get its roles assigned properly now using our LDAP server:
01 Mar 08:29:05 DEBUG [security.ldap] - Searching for roles for user ‘foo’, DN = ‘uid=foo,cn=admins,cn=users,dc=example,dc=com’, with filter (&(objectClass=univentionGroup)(memberUid={1})) in search base ‘cn=services,cn=groups,dc=example,dc=com’
Phew!
  • Are there two ways of group/role discovery for LDAP users, one in the Authentication Provider and one with a Role Service? What is the difference? Are they completely different things?
  • From the logs and behaviour it seems like the three “[security.ldap]” lines come from the Authentication Provider while the Role Service discovers them silently? Why does one discovery log something and the other doesn’t?
I’ll update https://gis.stackexchange.com/questions/477658/geoserver-does-not-find-ldap-groups-of-user momentarily, including the minimal configuration I ended up with. There is better formatting and higher search engine discovery on that site so I hope you don’t mind if I switch from the mailing list.
Cheers, Hannes
PS: Future reader, once you switch the Role Service your GeoServer user “admin” won’t become a GeoServer admin anymore. Make sure you have access to the “root” user’s master password or that your LDAP setup includes a user that will become GeoServer admin!
This also puzzles me. There are mentions to group search in both the
Authentication Provider settings form and the Role Service settings
form.
Maybe one of them can be used to retrieve user groups and the other
one retrieves user roles? Only speculating, but I see Geoserver has
the concept of both groups and roles, so that might be the cause.
Best regards,
César Martínez
   GIS developer
