Hello,
we're trying to get Geoserver authentiate via an AD, but the problem is that we cannot contact the AD directly (Firewall). Our company has installed a so called LDAP proxy, which uses a second functional account looking up login credentials at a provided LDAP_AUTH_URL which is a DN to the user entries in the AD.
Now my question: Is there any way to use Geoserver with a second user instead of letting Geoserver directly bind to the LDAP with the user credentials?
Thanks for your help,
Thomas
Hi Thomas,
I don’t think this is currently possible, but let me try to understand what you need: you are asking to use a fixed set of credentials to bind Geoserver to the LDAP proxy and then do some “search / lookup” on the ldap proxy with the real credentials to authenticate?
If this is not the case, can you try to explain exactly the authentication flow you need?
Mauro
2013/7/2 <Thomas.Wanderer@anonymised.com>
Hello,
we’re trying to get Geoserver authentiate via an AD, but the problem is that we cannot contact the AD directly (Firewall). Our company has installed a so called LDAP proxy, which uses a second functional account looking up login credentials at a provided LDAP_AUTH_URL which is a DN to the user entries in the AD.
Thomas
This SF.net email is sponsored by Windows:
Build for Windows Store.
http://p.sf.net/sfu/windows-dev2dev
Geoserver-users mailing list
Thanks for the fast replay! It is exactly what we were trying to do. I’m aware of the 2 options with LDAP… a direct binding to the LDAP with the provided login credentials, or using a second functional account which logs in and compares the login credentials with the one in the LDAP. Unfortunately our company does only allow the second case, even I would also prefer a direct binding…
Thomas
Von: maurobartolomeoli@anonymised.com [mailto:maurobartolomeoli@anonymised.com] Im Auftrag von Mauro Bartolomeoli
Gesendet: Dienstag, 2. Juli 2013 15:40
An: Wanderer, Thomas
Cc: GeoServer Mailing List List
Betreff: Re: [Geoserver-users] LDAP Authentification
Hi Thomas,
Mauro
Hello,
Thomas
Dott. Mauro Bartolomeoli
@mauro_bart
Senior Software Engineer
Via Poggio alle Viti 1187
also prefer a direct binding…****
Thomas****
Well, then a change to the code is needed to realize your desidered
behaviour. I think you would need to specify:
- the fixed account credentials used to bind
- the filter to use for authentication (I think we could reuse the "filter
used to lookup user" that is present on 2.4); do you have an example of
filter that you use for authentication on the ldap proxy?
It's not trivial, but not that hard to implement.
If you wish to add have it implemented I think you have some options:
- try to create a patch yourself and issue a pull request
- sponsor someone to implement it for you
Mauro
@mauro_bart
Yes, we have the following setup:
The functional account which makes the bind:
AuthLDAPBindDN “CN=ldapagent,OU=Benutzer,OU=_,DC=,DC=,DC=”
AuthLDAPBindPassword ********
And we have the server URL with filter:
AuthLDAPURL “ldap://ldap-proxy..de:389/DC=,DC=,DC=?sAMAccountName?sub?(objectClass=user)”
Actually one would only need 2 additional fields for the functional account/password in the LDAP Auth setup, but we do not have the resources right now for patching Geoserver. I would fin both LDAP Auth mechanisms nice being supported in the future,
Thomas
Well, then a change to the code is needed to realize your desidered behaviour. I think you would need to specify:
the filter to use for authentication (I think we could reuse the “filter used to lookup user” that is present on 2.4); do you have an example of filter that you use for authentication on the ldap proxy?
It’s not trivial, but not that hard to implement.
Mauro
