Legend problem in GeoExt Styler
Hi there,
I installed GeoExt Styler for Geoserver and could start it. If I then choose
a layer I can't see any legend or rules and have no chance to edit any sdl.
But I see the layers.
Firebug says: "request.responseXML is null". I can't get the
solution(stupid), but I think he can't find the sld-files. Is this any about
a proxy?
Any ideas?
thx,
Pete
View this message in context: http://www.nabble.com/Legend-problem-in-GeoExt-Styler-tp23721225p23721225.html
Hi Pete,
The styler extension also requires that you have the restconfig plugin installed as well. Have you installed that plugin?
-Justin
Hi there,
a proxy?
Any ideas?
thx,
Pete
Justin Deoliveira
OpenGeo - http://opengeo.org
I did, copying this plugin(war-file) to the "..geoserver/WEB-INF/lib"
-Directory should be enough. Is there anything else to do. I think it's more
like an proxy problem, isn't it?
thx,
Pete
Justin Deoliveira-6 wrote:
Hi Pete,
installed as well. Have you installed that plugin?-Justin
Hi there,
choose
sdl.
about
a proxy?
Any ideas?
thx,
Pete--
Justin Deoliveira
Enterprise support for open source geospatial.------------------------------------------------------------------------------
Register Now for Creativity and Technology (CaT), June 3rd, NYC. CaT
is a gathering of tech-side developers & brand creativity professionals.
Meet
the minds behind Google Creative Lab, Visual Complexity, Processing, &
iPhoneDevCamp asthey present alongside digital heavyweights like Barbarian
Group, R/GA, & Big Spaceship. http://www.creativitycat.com
Geoserver-users mailing list
View this message in context: http://www.nabble.com/Legend-problem-in-GeoExt-Styler-tp23721225p23736298.html
Possibly. How are you deploying the styler? Is it in the geoserver www directory? ie are you using the same base url that you would use to normally access geoserver, example:
http://localhost:8080/geoserver
http://localhost:8080/geoserver/www/styler/index.html
Also, are you using firebug? Are there any other messages that come up? Or any http calls that failed?
like an proxy problem, isn't it? thx,
PeteJustin Deoliveira-6 wrote:
Hi Pete,
-Justin
Hi there,
choose
sdl.
about
a proxy?
Any ideas?
thx,
Pete--
Justin Deoliveira
Meet
the minds behind Google Creative Lab, Visual Complexity, Processing, & iPhoneDevCamp asthey present alongside digital heavyweights like Barbarian
Group, R/GA, & Big Spaceship. http://www.creativitycat.com _______________________________________________
Justin Deoliveira
Hi.
I am facing exactly same problem. I have copied the jar file downloaded from
http://sourceforge.net/projects/geoserver/files/GeoServer%20Extensions/1.7.6/geoserver-1.7.6-restconfig-plugin.zip/download
to my geoserver\lib folder as well as
geoserver\webapps\geoserver\WEB-INF\lib folder.
But still I am not able to see any options in the legends. The add new and
delete selected buttons at the bottom are also not active.
I am able to see and apply my own layers hosted on localhost. But I am not
able to edit any of the styles.
Please help.
Jay.
normally access geoserver, example:http://localhost:8080/geoserver
http://localhost:8080/geoserver/www/styler/index.htmlAlso, are you using firebug? Are there any other messages that come up?
more
thx,
Hi Pete,
Hi there,
choose
sdl.
about
a proxy?
Any ideas?
thx,
Pete--
Justin Deoliveira
Meet
Barbarian
https://lists.sourceforge.net/lists/listinfo/geoserver-users--
Justin Deoliveira
Meet
iPhoneDevCamp as they present alongside digital heavyweights like
Barbarian
Group, R/GA, & Big Spaceship. http://p.sf.net/sfu/creativitycat-com
View this message in context: http://www.nabble.com/Legend-problem-in-GeoExt-Styler-tp23721225p24897284.html
Please note that I am using:
Windows XP SP2,
Geoserver 1.7.5
Firefox 3.5.2
Jay Mahadeokar wrote:
Hi.
from
http://sourceforge.net/projects/geoserver/files/GeoServer%20Extensions/1.7.6/geoserver-1.7.6-restconfig-plugin.zip/downloadto my geoserver\lib folder as well as
geoserver\webapps\geoserver\WEB-INF\lib folder.But still I am not able to see any options in the legends. The add new
and delete selected buttons at the bottom are also not active.I am able to see and apply my own layers hosted on localhost. But I am
not able to edit any of the styles.Please help.
more
thx,
Hi Pete,
Hi there,
choose
sdl.
about
a proxy?
Any ideas?
thx,
Pete--
Justin Deoliveira
professionals.
Meet
Barbarian
Justin Deoliveira
Meet
Barbarian
View this message in context: http://www.nabble.com/Legend-problem-in-GeoExt-Styler-tp23721225p24897312.html
This is the log message which I see:
http://www.nabble.com/file/p24898753/geoserverLog.log geoserverLog.log . I
think the Rest Plugin is not configured / working properly. Note that I am
now using restConfig 1.7.5 same version as my geoserver.
Please help... Urgent
Windows XP SP2,
Geoserver 1.7.5
Firefox 3.5.2Regards,
Hi.
from
more
thx,
Hi Pete,
Hi there,
choose
any
sdl.
any
about
a proxy?
Any ideas?
thx,
Pete--
Justin Deoliveira
professionals.
Meet
Barbarian
Justin Deoliveira
Meet
Barbarian
View this message in context: http://www.nabble.com/Legend-problem-in-GeoExt-Styler-tp23721225p24898753.html
Looking through the log I don't see any requests from the restconfig plug-in. Are you sure it is installed? Is there a restconfig-*.jar in the WEB-INF/lib directory of your geoserver installation?
This is the log message which I see: http://www.nabble.com/file/p24898753/geoserverLog.log geoserverLog.log . I
Windows XP SP2,
Geoserver 1.7.5
Hi.
from
http://localhost:8080/geoserver/www/styler/index.htmlAlso, are you using firebug? Are there any other messages that come up? Or any http calls that failed?
more
Hi Pete,
-Justin
Hi there,
choose
any
sdl.
any
about
a proxy?
Any ideas?
thx,
Pete--
Justin Deoliveira
professionals.
Meet
Barbarian
Justin Deoliveira
Register Now for Creativity and Technology (CaT), June 3rd, NYC. CaT is a gathering of tech-side developers & brand creativity professionals.
Meet
the minds behind Google Creative Lab, Visual Complexity, Processing, & iPhoneDevCamp as they present alongside digital heavyweights like
Barbarian Group, R/GA, & Big Spaceship. http://p.sf.net/sfu/creativitycat-com _______________________________________________
Justin Deoliveira
I have doubled checked the
..\geoserver-1.7.5-bin\geoserver-1.7.5\webapps\geoserver\WEB-INF\lib folder.
I have the restconfig-1.7.5.jar file there.
I am again attaching the most recent log here -
http://www.nabble.com/file/p25003772/geoserver.log geoserver.log
(Log file uploaded from ..\geoserver-1.7.5-bin\geoserver-1.7.5\data_dir\logs
folder.
Please see if you can figure out the problem.
Thanks in advance.
Jay.
the WEB-INF/lib directory of your geoserver installation?Jay Mahadeokar wrote:
I
am
Windows XP SP2,
Geoserver 1.7.5
Hi.
from
up?
it's
more
thx,
Hi Pete,
plugin
Hi there,
then
choose
any
sdl.
any
about
a proxy?
Any ideas?
thx,
Pete--
Justin Deoliveira
professionals.
Meet
Barbarian
Justin Deoliveira
professionals.
Meet
Barbarian
Justin Deoliveira
Let Crystal Reports handle the reporting - Free Crystal Reports 2008
30-Day
trial. Simplify your report design, integration and deployment - and focus
on
what you do best, core application coding. Discover what's new with
Crystal Reports now. http://p.sf.net/sfu/bobj-july
View this message in context: http://www.nabble.com/Legend-problem-in-GeoExt-Styler-tp23721225p25003772.html
I still don't see much in the logs. The only errors i see have to do with a style being invalid with respect to its dataset (the NAME attribute being used in the sld, but not present in the data).
the only other thing I can suggest is to try and send me some of the data you are working with, and i can try to reproduce the problem on my end.
-Justin
..\geoserver-1.7.5-bin\geoserver-1.7.5\webapps\geoserver\WEB-INF\lib folder. I have the restconfig-1.7.5.jar file there.I am again attaching the most recent log here - http://www.nabble.com/file/p25003772/geoserver.log geoserver.log (Log file uploaded from ..\geoserver-1.7.5-bin\geoserver-1.7.5\data_dir\logs
folder.
Please see if you can figure out the problem.Thanks in advance.
I
am
Windows XP SP2,
Geoserver 1.7.5
Hi.
from
it's
more
Hi Pete,
plugin installed as well. Have you installed that plugin?-Justin
Hi there,
then
choose
any
sdl.
any
about
a proxy?
Any ideas?
thx,
Pete--
Justin Deoliveira
professionals.
Meet
Barbarian
Justin Deoliveira
professionals.
Meet
Justin Deoliveira
30-Day trial. Simplify your report design, integration and deployment - and focus
on what you do best, core application coding. Discover what's new with Crystal Reports now. http://p.sf.net/sfu/bobj-july
Justin Deoliveira
I cannot get the legend to work either. I'm using:
Ubuntu 8.04.3
geoserver 2.0.1
restconfig 2.0.1
styler-1.7.3
I am using the url http://192.168.0.31:8080/geoserver/www/styler/index.html
and the error i get back from firebug is:
http://192.168.0.31:8080/geoserver/www/styler/script/Styler.js
Line 72
I can get the legend working in Windows7 with the same setup listed above
(Windows7, geoserver 2.0.1, restconfig 2.0.1, styler-1.7.3) except i have to
change the url to
http://192.168.0.127:8080/geoserver/data/www/styler/index.html
Any help would be greatly appreciated. Thx,
Dana
attribute being used in the sld, but not present in the data).the only other thing I can suggest is to try and send me some of the
end.-Justin
View this message in context: http://old.nabble.com/Legend-problem-in-GeoExt-Styler-tp23721225p27800375.html
dana_newblit wrote:
Ubuntu 8.04.3
geoserver 2.0.1
restconfig 2.0.1
styler-1.7.3I am using the url
http://192.168.0.31:8080/geoserver/www/styler/index.html and the error i
Line 72I can get the legend working in Windows7 with the same setup listed above
to change the url to
http://192.168.0.127:8080/geoserver/data/www/styler/index.htmlAny help would be greatly appreciated. Thx,
Dana
Did anyone solve this problem? I get exactly the same error using FF3.6.3
and Geoserver 2.0.2 on WinXP.
I have checked the REST config:
http://localhost:8080/geoserver/rest/styles/point gives this as a relply:
Style "point" default_point.sld
If I open the sld, it's a the correct SLD.
Any tips?
View this message in context: http://old.nabble.com/Legend-problem-in-GeoExt-Styler-tp23721225p29648221.html
