[Geoserver-users] legend shows out-of-scale style
Hi All,
this is probably more a SLD-issue. I use a scale-sensitive SLD as below. But
the legend (in mapbender) always shows both lines, even when I adress
directly to the server
(http://129.143.96.48:8080/geoserver/wms/GetLegendGraphic?VERSION=1.0.0&FORM
AT=image/png&WIDTH=20&HEIGHT=20&LAYER=shapes_bw:krei25).
I'm using Geoserver 1.5.3. Does anybody know some help?
Best regards,
Tilo
      <FeatureTypeStyle>
        <Rule>
          <Name>Rule 1</Name>
          <Title>Kreisgrenze</Title>
          <MinScaleDenominator>100</MinScaleDenominator>
          <MaxScaleDenominator>1000000</MaxScaleDenominator>
          <LineSymbolizer>
            <Stroke>
              <CssParameter name="stroke">#B4B6D6</CssParameter>
              <CssParameter name="stroke-width">2</CssParameter>
            </Stroke>
          </LineSymbolizer>
        </Rule>
        <Rule>
          <MinScaleDenominator>1000001</MinScaleDenominator>
          <MaxScaleDenominator>10000000</MaxScaleDenominator>
          <LineSymbolizer>
            <Stroke>
              <CssParameter name="stroke">#7A7AB7</CssParameter>
              <CssParameter name="stroke-width">1</CssParameter>
            </Stroke>
          </LineSymbolizer>
        </Rule>
Hi Tilo,
I believe this is the intended behavior. Since there is not bbox
supplied to a GetLegendGraphic request there is not really a way for it
to figure out the current scale. So it creates a legend which depicts
the style for every scale.
I could see this as being a useful extension, but not trivial to implement.
-Justin
Tilo Wütherich wrote:
Hi All,
Best regards,
Tilo
      <FeatureTypeStyle>
        <Rule>
          <Name>Rule 1</Name>
          <LineSymbolizer>
            <Stroke>
            </Stroke>
          </LineSymbolizer>
        </Rule>
        <Rule>
          <LineSymbolizer>
            <Stroke>
            </Stroke>
          </LineSymbolizer>
        </Rule>
Defy all challenges. Microsoft(R) Visual Studio 2008.
Geoserver-users mailing list
!DSPAM:4007,479dc75b115901849620573!
Justin Deoliveira
The Open Planning Project
http://topp.openplans.org
Justin Deoliveira ha scritto:
Hi Tilo,
I had a look at the code and it seems we have a custom extension
that allows to specify a scale appending &scale=xxx (where xxx is the actual scale value, so if you want the legend for scale 1:1000 you'd have to specify 0.001).
I was not aware of it, probably one extension added during Saul's
work on legends... worth giving it a try.
Hi Andrea and Justin,
thanks for the info!
Tilo
to implement.
