[Geoserver-users] legend=true breaks kml output?
Hi All,
I've been away from the list for a while after switching projects, but
I'm back into geoserver territory.
I noticed a few posts on the JIRA issue tracker about the legend
generation affecting KML output for Google Earth. Has this been
addressed? I'm finding in my own dataset and the topp:states dataset
that generating the legend interrupts the rendering of the KML
file...I get a little over a dozen features before a parsing error in
GE.
Anyone interested digging deeper?
Damian Bradley,
Decarto Consulting Ltd.
Hi Damian,
I assume you are talking about this issue:
http://jira.codehaus.org/browse/GEOS-2286
Which version of geoserver are you using? I just tried with the latest and greatest and could not reproduce with topp:states. Are you running with a vanilla configuration, or one you have modified?
Damian Bradley wrote:
Hi All,
GE.
Damian Bradley,
Crystal Reports - New Free Runtime and 30 Day Trial
Check out the new simplified licensing option that enables unlimited royalty-free distribution of the report engine for externally facing server and web deployment. http://p.sf.net/sfu/businessobjects
Geoserver-users mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
Hey Justin,
I'm running 1.7.4 stock...though my server just suffered an electrical
failure so I won't be able to continue testing until it is replaced.
My issue wasn't quite the same as the one you linked...the network
link wasn't 'broken' but the data stopped loading half way through so
it displayed the first 12 states in the dataset...
Damian
On Thu, May 21, 2009 at 1:20 PM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
Hi Damian,
Hi All,
GE.
Damian Bradley,
Justin Deoliveira
Strange indeed. When you get your server back up and running can you send me the output of the request against the states layer. And the exact request being made. Thanks.
-Justin
Hey Justin,
Damian
Hi Damian,
Hi All,
GE.
Damian Bradley,
Justin Deoliveira
Justin Deoliveira
