Hello all.
I'm getting a error in both versions of geoserver, the 1.7 and 1.6. If the
data is stored as shapefile, the limit generation works fine, but if the
data comes from a database, in my case postgresql, it can't generate the
limits, and I must specify mannually them. Gives me this error (it's
braziliam portuguese):
N?o foi poss?vel construir uma transforma??o de SRS - No transformation
available from system "EllipsoidalCS[Ellipsoidal 2D CS. Axes: latitude,
longitude. Orientations: north, east. UoM: DMSH.]" to
"EllipsoidalCS[Geodetic 2D]".
The lookup SRS returns 4291, that is the correct number.
Thanks
View this message in context: http://www.nabble.com/Limit-generation-error-tp20480916p20480916.html
