[Geoserver-users] Links from WMS - Solved
Thank you Jukka,
This is the solution I was looking for. Very simple and effective. It worked smoothly.
Cheers.
JJ.
From: Rahkonen Jukka (MML) [mailto:jukka.rahkonen@anonymised.com]
Sent: Tuesday, November 17, 2015 1:47 AM
To: Jair Santos jsantos5954@anonymised.com; ‘GeoServer Mailing List List’ geoserver-users@lists.sourceforge.net
Subject: Re: [Geoserver-users] Links from WMS
We have saved links as well as some other formatting like line breaks into a text field of a database table as html-formatted strings. At least that works with Mapserver but why not with Geoserver as well. You will see a link if you click a red fishing restriction area in http://www.paikkatietoikkuna.fi/web/en/map-window?ver=1.17&zoomLevel=10&coord=413832.469_6948702.876&mapLayers=base_35+100+default,1373+100+default&&showMarker=true
The link is saved into the database as
www.ely-keskus.fi/pohjois-savo</a>
The referred site is under a DOS attack just now and the link does not show anything but normally it works.
-Jukka Rahkonen-
Jair Santos wrote:
Hello all,
I am requesting information from Geoserver in a popup overlay using WMS as source for a
