On Thu, Mar 12, 2015 at 10:09 AM, Tobias Reinicke <ramotswa@anonymised.com>
wrote:
Hi David,
Many thanks - that's some great info - if I may pry though - why is the
spatial search of SOLR not as good as PostGIS (as I don't know SOLR much I
don't know what to expect
) - I presume it's along the lines of PG has
better spatial indexes (indicies?)?
I don't have numbers to back what I'm about to say, but I think the search
is actually good, it's the data transfer that is not as fast as in
PostGIS...
that said, we would need to do some benchmarking to find that out, the
impression of SOLR being slower comes from trying to render
a lot of points coming from SOLR into GeoServer, which is definitely slower
than doing the same from PostGIS
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
