Happy to share a copy of some ftl's, here they are.
Also, I tested the topp:states layer and 'lo and behold', the templates are working for it, and I could also add a content.ftl under the "states" featureType dir and it was picked up. So the problem must be in my featureType itself, which for some reason doesn't have it's directory scanned for the presence of templates. This kinda makes sense, as opposed to the templates being wrong, as they work properly when set as global ones.
Here's what I have for that featureType:
- Namespace Info:
Name = CH2M
prefix = http://www.openplans.org/topp
- DataStore Info:
Feature Data Set ID = WORLD_PROJECTS
Namespace = CH2M
- featureType Info:
Name = WORLD_PROJECTS:vw_worldprojects (points to a PostGIS view named "vw_worldprojects")
- Geoserver Directory structure look like this:
Tomcat5
-->webapps
---->geoserver
------>data
-------->featureTypes
---------->WORLD_PROJECTS_vw_worldprojets
- When I select the data from the Demo Map Preview section, the data set is named:
CH2M:vw_worldprojects
Se anything grossly out of place?
Roger
-----Original Message-----
From: Justin Deoliveira [mailto:jdeolive@anonymised.com]
Sent: Friday, January 04, 2008 11:36 AM
To: Andre, Roger/SEA
Subject: Re: [Geoserver-users] Location of freemarker templates for specificFeatureTypes
Hmmm... strange. You are right, its the presence of the file that dictates if it engages or not. I will have to look into this one. Do you mind sharing an example of one of your templates that does not work?
Also, can you humor me by trying a request against the topp:states layer (this assumes that you are running with the data directory that ships with geoserver). It has templates included with it. Can you tell us if they are engaging or not?
-Justin
Roger.Andre@anonymised.com wrote:
Hi Justin,
That's correct, "myFeatureType" behaves as though no template were set. I have; title.ftl, description.ftl, time.ftl, and content.ftl set under that FeatureType. Looking at the log hadn't even crossed my mind, thanks for the suggestion. I cleared it out and then made a couple requests for data. There doesn't appear to be anything related to this problem in the output, but I've included it below for you to see. It seems more like the presense of the templates isn't even registering. Is there some sort of process to, "enable templates for this FeatureType"? I didn't spot one in the docs, it seemed more like the presence of an .ftl causes it to be read and used.
Log output below:
2008-01-05 11:19:12,843 WARN [geoserver.ows] -
ClientAbortException: java.net.SocketException: Software caused connection abort: socket write error
at org.apache.catalina.connector.OutputBuffer.doFlush(OutputBuffer.java:327)
at org.apache.catalina.connector.OutputBuffer.flush(OutputBuffer.java:293)
at org.apache.catalina.connector.CoyoteOutputStream.flush(CoyoteOutputStream.java:98)
at org.vfny.geoserver.util.PartialBufferedOutputStream2.flush(PartialBufferedOutputStream2.java:185)
at java.io.FilterOutputStream.flush(Unknown Source)
at org.vfny.geoserver.wms.responses.map.kml.KMZMapProducer.writeTo(KMZMapProducer.java:167)
at org.vfny.geoserver.wms.responses.GetMapResponse.writeTo(GetMapResponse.java:561)
at org.geoserver.ows.adapters.ResponseAdapter.write(ResponseAdapter.java:60)
at org.geoserver.ows.Dispatcher.response(Dispatcher.java:615)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:192)
at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:139)
at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:44)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:684)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:625)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:392)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:347)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:690)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:803)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:269)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:188)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:215)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:264)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274)
at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:110)
at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
at org.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(BasicProcessingFilter.java:178)
at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:229)
at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:148)
at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:213)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:174)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:117)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:108)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:151)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:874)
at org.apache.coyote.http11.Http11BaseProtocol$Http11ConnectionHandler.processConnection(Http11BaseProtocol.java:665)
at org.apache.tomcat.util.net.PoolTcpEndpoint.processSocket(PoolTcpEndpoint.java:528)
at org.apache.tomcat.util.net.LeaderFollowerWorkerThread.runIt(LeaderFollowerWorkerThread.java:81)
at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:689)
at java.lang.Thread.run(Unknown Source) Caused by:
at java.net.SocketOutputStream.socketWrite0(Native Method)
at java.net.SocketOutputStream.socketWrite(Unknown Source)
at java.net.SocketOutputStream.write(Unknown Source)
at org.apache.coyote.http11.InternalOutputBuffer.realWriteBytes(InternalOutputBuffer.java:747)
at org.apache.tomcat.util.buf.ByteChunk.flushBuffer(ByteChunk.java:432)
at org.apache.coyote.http11.InternalOutputBuffer.flush(InternalOutputBuffer.java:305)
at org.apache.coyote.http11.Http11Processor.action(Http11Processor.java:996)
at org.apache.coyote.Response.action(Response.java:183)
at org.apache.catalina.connector.OutputBuffer.doFlush(OutputBuffer.java:322)
... 50 more
2008-01-05 11:19:12,843 INFO [geoserver.ows] - Problem writing exception information back to calling client:
at org.geoserver.ows.LegacyServiceExceptionHandler.handleServiceException(LegacyServiceExceptionHandler.java:189)
at org.geoserver.ows.Dispatcher.exception(Dispatcher.java:1179)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:198)
... 46 more
Roger André
GIS Developer/Analyst
Enterprise Management Solutions
CH2M HILL
1100 112th Avenue NE
Suite 400
Bellevue, WA 98004
Direct 425.233.3042
roger.andre@anonymised.com
Developing People through Challenging Projects
From: geoserver-users-bounces@lists.sourceforge.net
[mailto:geoserver-users-bounces@lists.sourceforge.net] On Behalf Of
Justin Deoliveira
Sent: Friday, January 04, 2008 10:58 AM
Hi Roger,
So the output "myFeatureType" is behaving as if there was no template?
Which template are you attempting to use? title? description?
Also do you see any errors that occur in the log when you make a request against the layer which has the template? I wonder if perhaps the template has an error in it and is just being skipped.
-Justin
Hello fellow GeoServer users,
I'm a brand-new member of this list, and a new user of GeoServer as
well. I'm extremely "chuffed" about the things GeoServer can do, and
am having a great time setting up a little demo to display KML and
GeoRSS output from a PostGIS database. However, I seem to have hit a
small snag in my use of .ftl template files. I've been able to
successfully control the output of a single layer by using global
overrides and template files located under,
"GEOSERVER_DATA_DIR/featureTypes/". Now that I have a few more
layers to display, I would like to have type-specific templates, and
have moved my .ftl files into the specific featureType directory,
"GEOSERVER_DATA_DIR/featureTypes/myfeatureType/". As a result of
this change, myfeatureType now lacks any sort of templated control.
I'm using version 1.6.0 RC 2 of the geoserver.war, and would like to
know if anyone could shed some light on this behavior.
Roger
Roger André
CH2M HILL
Suite 400
Bellevue, WA 98004
Direct 425.233.3042
roger.andre@anonymised.com <mailto:roger.andre@anonymised.com>
--- This SF.net email is sponsored by: Microsoft Defy all challenges.
Microsoft(R) Visual Studio 2005.
!DSPAM:4007,477e7fe7129412085621377!
Geoserver-users mailing list
Justin Deoliveira
The Open Planning Project
http://topp.openplans.org
!DSPAM:4007,477e85c3138206491211187!
Justin Deoliveira
content.ftl (1.9 KB)
description.ftl (1.68 KB)
