[Geoserver-users] Location of styles list
In 1.6.5 the styles are reachable through a URL in the form of servername/rest/styles for example:
http://giswebservices.massgis.state.ma.us/geoserver/rest/styles
One of our client apps uses this… the 1.7.2 GeoServer doesn’t seem to have the same URL and I’ve
having trouble figuring out a URL that gives me that list… anyone know?
Hi Aleda,
As far as I know 1.6.x made styles available only from http://…/geoserver/styles (no "rest"). And only allows you to access styles directly. In other words:
http://…/geoserver/styles/default_point.sld should return the SLD document. But:
should give you back a 404.
The rest configuration extensions for 1.7.x (officially released in the up and coming 1.7.3 release) will provide listing functionality, and will make styles available from:
http://…/geoserver/rest/styles
As far as I know the rest configuration extensions never lived on 1.6.x...
-Justin
_http://giswebservices.massgis.state.ma.us/geoserver/rest/styles_
One of our client apps uses this... the 1.7.2 GeoServer doesn't seem to have the same URL and I've
having trouble figuring out a URL that gives me that list... anyone know?
Open Source Business Conference (OSBC), March 24-25, 2009, San Francisco, CA
-OSBC tackles the biggest issue in open source: Open Sourcing the Enterprise
-Strategies to boost innovation and cut costs with open source participation
-Receive a $600 discount off the registration fee with the source code: SFAD
http://p.sf.net/sfu/XcvMzF8H
Geoserver-users mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
Ah, interesting. Well, come to think of it, I have a
1.6.5-saul-special-version probably :slight_smile:
Because I have
So perfect, in 1.7.3 the styles will be exactly where I'm expecting them
to be.
-----Original Message-----
From: Justin Deoliveira [mailto:jdeolive@anonymised.com]
Sent: Friday, March 06, 2009 4:36 PM
To: Freeman, Aleda (EEA)
Subject: Re: [Geoserver-users] Location of styles list
Hi Aleda,
document. But:
1.6.x...
-Justin
to have the same URL and I've having trouble figuring out a URL that
-------- Open Source Business Conference (OSBC), March 24-25, 2009,
San Francisco, CA -OSBC tackles the biggest issue in open source: Open
Sourcing the Enterprise -Strategies to boost innovation and cut costs
with open source participation -Receive a $600 discount off the
Justin Deoliveira
Ha, Saul putting his finishing touches on again :slight_smile: Now that I think about I do seem to remember saul being interested in the rest config extensions at one point, so it is possible he backported to 1.6.x.
One thing to note is is that the format that the styles are returned in the official version which will be part of 1.7.3 is different than the format used by the extension you are currently running, so i am guessing this will be an issue for your client app.
Do you know what format the client is requesting the data in? Is it HTML or XML? In other words is it calling:
or
http://…/geoserver/rest/style.xml
-Justin
1.6.5-saul-special-version probably :slight_smile: Because I have
to be.
From: Justin Deoliveira [mailto:jdeolive@anonymised.com] Sent: Friday, March 06, 2009 4:36 PM
Hi Aleda,
document. But:
1.6.x...
-Justin
One of our client apps uses this... the 1.7.2 GeoServer doesn't seem to have the same URL and I've having trouble figuring out a URL that gives me that list... anyone know?
-------- Open Source Business Conference (OSBC), March 24-25, 2009, San Francisco, CA -OSBC tackles the biggest issue in open source: Open
Sourcing the Enterprise -Strategies to boost innovation and cut costs with open source participation -Receive a $600 discount off the registration fee with the source code: SFAD http://p.sf.net/sfu/XcvMzF8H
Justin Deoliveira
Justin Deoliveira
The client actually tries to grab the style by name:
http://giswebservices.massgis.state.ma.us/geoserver/rest/styles/GISDATA.
LANDUSE_POLY::21_Classes_1999_Solid
Then it looks for any scale info such as:
<sld:MinScaleDenominator>0</sld:MinScaleDenominator>
<sld:MaxScaleDenominator>200000</sld:MaxScaleDenominator>
If the layer is outside the scale range, it's title is "greyed out" in
the legend area.
The greyed out is a hint to the user as to why the data isn't drawing on
the map.
So, this is minor, but nice to have.
That's for the clue about the coming format change - I'll add that to my
"check when 1.7.3 is out" list!
Sent: Friday, March 06, 2009 6:14 PM
or
-Justin
them to be.
Hi Aleda,
document. But:
1.6.x...
-Justin
Open
Justin Deoliveira
Justin Deoliveira
Hi Aleda,
So the only thing that will require a change will be to append a ".sld" to the style being requested. ie:
http://giswebservices.massgis.state.ma.us/geoserver/rest/styles/GISDATA.LANDUSE_POLY::21_Classes_1999_Solid.sld
-Justin
the legend area. The greyed out is a hint to the user as to why the data isn't drawing on
the map.
From: Justin Deoliveira [mailto:jdeolive@anonymised.com] Sent: Friday, March 06, 2009 6:14 PM
or
-Justin
Ah, interesting. Well, come to think of it, I have a 1.6.5-saul-special-version probably :slight_smile: Because I have http://giswebservices.massgis.state.ma.us/geoserver/rest/styles
So perfect, in 1.7.3 the styles will be exactly where I'm expecting them to be.
Hi Aleda,
-Justin
Justin Deoliveira
Justin Deoliveira
Justin Deoliveira
However... are you referring to the filename of the style or the id of
the style?
The addition of .sld makes me think you mean the filename of the file.
For example, this style's line in catalog.xml reads:
<style filename = "GISDATA.LANDUSE_POLY--21_Classes_1999_Solid.xml" id =
"GISDATA.LANDUSE_POLY::21_Classes_1999_Solid" />
We have a little scheme here where the filename and the id are not
exactly the same.
The client is currently asking for the id, although I could change that
to be the filename.
Sent: Monday, March 09, 2009 4:31 PM
Hi Aleda,
-Justin
the legend area.
on the map.
my "check when 1.7.3 is out" list!
or
-Justin
them to be.
Hi Aleda,
access
document. But:
1.6.x...
-Justin
Open
costs
Justin Deoliveira
Justin Deoliveira
Justin Deoliveira
Nope, the name of the style is still used. The .sld is not necessarily referring to the file extension, but the format in which the client is requesting back. .sld refers to getting the SLD version of it back, .html would refer to an HTML representation of the file, etc... Does that make any sense?
the style?
exactly the same.
to be the filename.
From: Justin Deoliveira [mailto:jdeolive@anonymised.com] Sent: Monday, March 09, 2009 4:31 PM
Hi Aleda,
-Justin
the legend area.
The greyed out is a hint to the user as to why the data isn't drawing on the map.
That's for the clue about the coming format change - I'll add that to my "check when 1.7.3 is out" list!
or
-Justin
Hi Aleda,
-Justin
Open
Justin Deoliveira
Justin Deoliveira
Justin Deoliveira
Justin Deoliveira
