Home directory on windows? We had code choke in the past because of
spaces in the path... can you check by moving GeoServer on a path
that does not have spaces inside?
No, I am using Ubuntu/Linux, and there are no spaces in the path. But now, surprisingly, Geoserver fail to start and shows the following error. Things seems to get more complicated now!!!
3649 [FINA] org.vfny.geoserver.global.GeoServer - Creating GeoServer
Message from syslogd@anonymised.com at Tue Aug 28 09:05:07 2007 …
localhost kernel: [510031.932000] Oops: 0000 [#2]
localhost kernel: [510031.932000] SMP
localhost kernel: [510031.932000] CPU: 0
localhost kernel: [510031.932000] EIP: 0060:[find_get_page+38/96] Tainted: P VLI
localhost kernel: [510031.932000] EFLAGS: 00210002 (2.6.20-16-generic #2)
localhost kernel: [510031.932000] EIP is at find_get_page+0x26/0x60
localhost kernel: [510031.932000] eax: 008b2a64 ebx: 0000007e ecx: 008b2a64 edx: 00000000
localhost kernel: [510031.932000] esi: de7b6178 edi: de7b6178 ebp: dc8e1180 esp: ddd95ec4
localhost kernel: [510031.932000] ds: 007b es: 007b ss: 0068
localhost kernel: [510031.932000] Process java (pid: 22707, ti=ddd94000 task=c217d030 task.ti=ddd94000)
localhost kernel: [510031.932000] Stack: 00000117 00000000 c0159a13 c017f2b7 00200246 ddd95f60 f31a4668 dc8e11c8
localhost kernel: [510031.932000] de7b60d4 0000007e 00000000 00000002 c03a9b08 00000001 8b7ff000 c0429e80
localhost kernel: [510031.932000] c016445a f559ef40 c01022c5 dfe401e0 00000001 00000005 00000001 00000000
localhost kernel: [510031.932000] Call Trace:
localhost kernel: [510031.932000] [filemap_nopage+339/928] filemap_nopage+0x153/0x3a0
localhost kernel: [510031.932000] [getname+167/208] getname+0xa7/0xd0
localhost kernel: [510031.932000] [__handle_mm_fault+330/2624] __handle_mm_fault+0x14a/0xa40
localhost kernel: [510031.932000] [__switch_to+341/496] __switch_to+0x155/0x1f0
localhost kernel: [510031.932000] [do_page_fault+296/1520] do_page_fault+0x128/0x5f0
localhost kernel: [510031.932000] [do_page_fault+0/1520] do_page_fault+0x0/0x5f0
localhost kernel: [510031.932000] [error_code+124/144] error_code+0x7c/0x90
localhost kernel: [510031.932000] =======================
localhost kernel: [510031.932000] Code: bf 00 00 00 00 83 ec 08 89 74 24 04 89 c6 8d 40 10 89 1c 24 89 d3 e8 7a 79 19 00 8d 46 04 89 da e8 c0 7c 09 00 85 c0 89 c1 74 0d <8b> 00 89 ca f6 c4 40 75 1f f0 ff 42 04 f0 ff 46 10 fb 90 8d b4
localhost kernel: [510031.932000] EIP: [find_get_page+38/96] find_get_page+0x26/0x60 SS:ESP 0068:ddd95ec4
<br>-- <br> Aitor Calero García<br> [aitor.calero@anonymised.com](mailto:aitor.calero@anonymised.com)<br> [aitor.calero@anonymised.com](mailto:aitor.calero@anonymised.com)<br> Atos Research & Innovation<br> Atos Origin Spain<br> C/ Albarracín, 25 - 28037 Madrid (Spain) <br> Tel. (+34) 91 214 8805 <br> Fax. (+34) 91 754 3252<br> [http://www.atosresearch.eu](http://www.atosresearch.eu)<br> Before printing this e-mail, think if it is really necessary<br><br>
