On Thu, Mar 3, 2016 at 4:49 PM, Andrew Chamberlain <
andy_chamberlain@anonymised.com> wrote:
Hi All,
Hope this isn't a noddy question. Just wondering if anyone knew whether
it's possible to audit (i.e. log to file) login attempts to the Geoserver
web admin interface?
I've had a look at the monitoring extension, but that only seems to audit
data requests.
nope, we don't have anything doing that... it should however be possible to
add it as a new plugin, or as an extension of the monitoring module.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
