[Geoserver-users] logout geoserver from code
Hi people, am using geoserver 2.1.4, and i have a doubt, i need a routine or a way to logout an user from de programation code,like
"http://10.8.192.221/geoserver/j_spring_security_check"
i need that to exit from geoserver, please need help.
thanks
This message was sent using IMP, the Internet Messaging Program.
Este mensaje le ha llegado mediante el servicio de correo electronico que ofrece Infomed para respaldar el cumplimiento de las misiones del Sistema Nacional de Salud. La persona que envia este correo asume el compromiso de usar el servicio a tales fines y cumplir con las regulaciones establecidas
Infomed: http://www.sld.cu/
Hi, try sending a request including your session cookie to
http://10.8.192.221/geoserver/j_spring_security_logout
Christian
thanks
Symantec Endpoint Protection 12 positioned as A LEADER in The Forrester
Wave™: Endpoint Security, Q1 2013 and “remains a good choice” in the
endpoint security space. For insight on selecting the right partner to
tackle endpoint security challenges, access the full report.
http://p.sf.net/sfu/symantec-dev2dev
Geoserver-users mailing list
