[Geoserver-users] Looking for advice on issues with sorted rendering when seeding a layergroup
Hello,
Does anyone know what causes this error?
ERROR [geotools.rendering] - The sorted rendering moved from a set of sort attributes, to one that’s equal or greater, this is unexpected, bailing out to avoid an infinite loop
java.lang.IllegalStateException: The sorted rendering moved from a set of sort attributes, to one that’s equal or greater, this is unexpected, bailing out to avoid an infinite loop
I’m trying to cache a dataset which uses these options:
PHYSICALLEVEL
pl
It seems to work generally but the tile caching job just fails after a period of time.
Best Regards,
Paul
On Mon, Aug 15, 2016 at 11:50 AM, Paul Wittle <P.Wittle@anonymised.com>
wrote:
Hello,
attributes, to one that's equal or greater, this is unexpected, bailing out
sort attributes, to one that's equal or greater, this is unexpected,
I'm trying to cache a dataset which uses these options:
<VendorOption name="sortBy">PHYSICALLEVEL</VendorOption>
<VendorOption name="sortByGroup">pl</VendorOption>
period of time.
Can you please share the full stack trace and GeoServer version?
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Hi Andrea,
Stack trace follows and the version is 2.8.4.
Paul
— Stack trace
2016-08-08 11:17:54,600 ERROR [geotools.rendering] - The sorted rendering moved from a set of sort attributes, to one that’s equal or greater, this is unexpected, bailing out to avoid an infinite loop
at org.geotools.renderer.lite.ZGroupLayer.drawFeatures(ZGroupLayer.java:105)
at org.geotools.renderer.lite.StreamingRenderer.paint(StreamingRenderer.java:813)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:538)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:259)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:132)
at org.geoserver.wms.GetMap.executeInternal(GetMap.java:505)
at org.geoserver.wms.GetMap.run(GetMap.java:249)
at org.geoserver.wms.GetMap.run(GetMap.java:119)
at org.geoserver.wms.DefaultWebMapService.getMap(DefaultWebMapService.java:320)
at sun.reflect.GeneratedMethodAccessor305.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:319)
at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:183)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:150)
at org.geoserver.kml.WebMapServiceKmlInterceptor.invoke(WebMapServiceKmlInterceptor.java:34)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:172)
at org.geoserver.gwc.wms.CacheSeedingWebMapService.invoke(CacheSeedingWebMapService.java:62)
at org.geoserver.gwc.wms.CacheSeedingWebMapService.invoke(CacheSeedingWebMapService.java:36)
at org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:80)
at org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:55)
at org.geoserver.ows.util.RequestObjectLogger.invoke(RequestObjectLogger.java:33)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:202)
at com.sun.proxy.$Proxy73.getMap(Unknown Source)
at sun.reflect.GeneratedMethodAccessor304.invoke(Unknown Source)
at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:845)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:275)
at org.geoserver.gwc.GWC.dispatchOwsRequest(GWC.java:1235)
at org.geoserver.gwc.layer.GeoServerTileLayer.dispatchGetMap(GeoServerTileLayer.java:625)
at org.geoserver.gwc.layer.GeoServerTileLayer.getMetatilingReponse(GeoServerTileLayer.java:569)
at org.geoserver.gwc.layer.GeoServerTileLayer.getTile(GeoServerTileLayer.java:518)
at org.geoserver.gwc.GWC.dispatch(GWC.java:680)
at org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:84)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:618)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:725)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:291)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:239)
at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:28)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:75)
at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:71)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:71)
at org.springframework.orm.hibernate3.support.OpenSessionInViewFilter.doFilterInternal(OpenSessionInViewFilter.java:198)
at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:76)
at org.geoserver.monitor.MonitorFilter.doFilter(MonitorFilter.java:138)
at org.geoserver.flow.controller.IpBlacklistFilter.doFilter(IpBlacklistFilter.java:95)
at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:46)
at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:50)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73)
at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:54)
at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:150)
at org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:83)
at org.geoserver.security.GeoServerAuthenticationKeyFilter.doFilter(GeoServerAuthenticationKeyFilter.java:105)
at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:53)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:135)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:87)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:48)
at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:44)
at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:88)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:219)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:106)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:501)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:142)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:79)
at org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:610)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:88)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:537)
at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1085)
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:658)
at org.apache.coyote.http11.Http11AprProtocol$Http11ConnectionHandler.process(Http11AprProtocol.java:277)
at org.apache.tomcat.util.net.AprEndpoint$SocketProcessor.doRun(AprEndpoint.java:2407)
at org.apache.tomcat.util.net.AprEndpoint$SocketProcessor.run(AprEndpoint.java:2396)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.lang.Thread.run(Unknown Source)
2016-08-08 11:17:54,600 ERROR [geoserver.ows] -
org.geoserver.platform.ServiceException: Rendering process failed
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:568)
Caused by: java.lang.IllegalStateException: The sorted rendering moved from a set of sort attributes, to one that’s equal or greater, this is unexpected, bailing out to avoid an infinite loop
… 146 more
2016-08-08 11:17:56,475 ERROR [geotools.map] - Call MapContent dispose() to prevent memory leaks
On Mon, Aug 15, 2016 at 11:50 AM, Paul Wittle <P.Wittle@…7193…> wrote:
Hello,
PHYSICALLEVEL
pl
Ing. Andrea Aime
@geowolf
Technical Lead
Hi Paul,
thanks for the stack trace. I had a look at the code but nothing stands out. In order to debug this one I’ll need a bug report, with
a small enough set of sample data, styles, and a request that makes it happen
On Tue, Aug 16, 2016 at 10:10 AM, Paul Wittle <P.Wittle@anonymised.com> wrote:
Hi Andrea,
Paul
— Stack trace
… 146 more
From: andrea.aime@anonymised.com [mailto:andrea.aime@anonymised.com] On Behalf Of Andrea Aime
Sent: 15 August 2016 19:27
To: Paul Wittle
Cc: geoserver-users@anonymised.comsourceforge.net
Subject: Re: [Geoserver-users] Looking for advice on issues with sorted rendering when seeding a layergroup
On Mon, Aug 15, 2016 at 11:50 AM, Paul Wittle <P.Wittle@anonymised.com> wrote:
Hello,
PHYSICALLEVEL
pl
Ing. Andrea Aime
@geowolf
Technical Lead
“This e-mail is intended for the named addressee(s) only and may contain information about individuals or other sensitive information and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this email in error, kindly disregard the content of the message and notify the sender immediately. Please be aware that all email may be subject to recording and/or monitoring in accordance with relevant legislation.”
Ing. Andrea Aime
@geowolf
Technical Lead
Hi Paul,
I’m not ignoring you, I did not follow up because I don’t have anything else to add, without a way to reproduce I won’t be able to help.
The stack traces you’ve shared indeed do not point to a particular location, sorry.
I checked, it does not seem like GWC is logging the internal request made by the tile seeder (which would have been
a better way to locate the problematic area), but who knows, maybe increasing the geoserver logging level to
“devel” mode might provide some hints.
On Fri, Aug 19, 2016 at 11:14 AM, Paul Wittle <P.Wittle@anonymised.com> wrote:
Hi Andrea,
As I said offline I’m going to be struggling with the data sample as this is happening when using OS MasterMap data.
I’ve run it again with a load of debugging options on in order to try and see if I could log which bbox was being processed when it fails. As yet I have still not managed to find an issue it terms of the actual tiles as they seem to generate fine but then kill the thread.
I did find this stack trace:
t(LayerCacheInfoBuilder.java:274)
at org.geowebcache.util.FileUtils.traverseDepth(FileUtils.java:100)
at org.geowebcache.util.FileUtils.traverseDepth(FileUtils.java:106)
at org.geowebcache.diskquota.LayerCacheInfoBuilder$ZoomLevelVisitor.call(LayerCacheInfoBuilder.java:235)
at org.geowebcache.diskquota.LayerCacheInfoBuilder$ZoomLevelVisitor.call(LayerCacheInfoBuilder.java:187)
at java.util.concurrent.FutureTask.run(Unknown Source)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(Unknown Source)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source)
java.lang.NullPointerException
at org.geowebcache.diskquota.LayerCacheInfoBuilder$ZoomLevelVisitor.accept(LayerCacheInfoBuilder.java:274)
log4j:WARN File option not set for appender [geoserverlogfile].
log4j:WARN Are you using FileAppender instead of ConsoleAppender?
Does that give any better clues?
It was in the tomcat8-stderr log and I think it might have been because I seleted the log to stdOut option.
Paul
Sent: 16 August 2016 09:32
To: Paul Wittle
Hi Paul,
Hi Andrea,
Paul
— Stack trace
… 146 more
From: andrea.aime@anonymised.com… [mailto:andrea.aime@anonymised.com] On Behalf Of Andrea Aime
To: Paul Wittle
Hello,
PHYSICALLEVEL
pl
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
Thanks Ian and Andrea,
Sorry, I didn’t mean to come across as pushy Andrea. I didn’t think you were ignoring me; to be honest I just decided to pick it up again briefly this morning as I’ve been doing other work all week.
The trouble is that we have so many factors that could be at play, the data we have loaded is much bigger than a sample and if the error is relating to the quantity of records to sort then a sample is unlikely to replicate the error. My research into the issue so far seems to indicate that the data may not be the issue but perhaps it is something to do with the Oracle driver or the way GWC is monitoring the seed request.
Whilst I note your comment the stack trace below mentions the disk quota which is something we did look at using but decided against. There are a few odd error messages I’ve never been able to resolve on our system including No JTDS jar on classpath and an incorrect JDBC password which I can’t track down. I wondered if the password was linked to the disk quota but I have been ignoring it as we don’t use the disk quota and the error is not linked to anything noticeable. It tends to appear at start up mostly.
The layers being used are relatively large and in an Oracle database. The styles being applied are also relatively complex and the Oracle data is actually being provided by views loaded into GeoServer as sql_views. Add to this the complication of using a layer group and sorting Z index across the layers and it is quite an ask for the renderer; hence why I’m keen to cache.
Should I try it without the z grouping across layers and see if it runs?
Paul
Hi Paul,
On Fri, Aug 19, 2016 at 11:14 AM, Paul Wittle <P.Wittle@…7193…> wrote:
Hi Andrea,
Paul
From: andrea.aime@…84… [mailto:andrea.aime@…84…] On Behalf Of Andrea Aime
To: Paul Wittle
Hi Paul,
On Tue, Aug 16, 2016 at 10:10 AM, Paul Wittle <P.Wittle@…7193…> wrote:
Hi Andrea,
Paul
— Stack trace
… 146 more
Hi Andrea,
Just to give a quick update on this, I tried caching the OS Mastermap as landline which means I only used one layer which is styled with the sortBy parameters. This worked successfully so it is almost definitely related to the interaction between the two datasets.
In terms of assessing the data, am I looking for two features in a single layer with the same physicallevel or something like that?
Alternatively, perhaps someone could point me towards the source code which generates the error message so I can have a think about how the data might get me to the exception. If I can work that out then I stand a chance of analysing the datasets to identify a likely bbox which will fail.
Many thanks,
Paul
Hi Paul,
Hi Andrea,
Paul
To: Paul Wittle
Hi Paul,
Hi Andrea,
Paul
— Stack trace
… 146 more
To: Paul Wittle
Hello,
PHYSICALLEVEL
pl
On Fri, Sep 2, 2016 at 10:04 AM, Paul Wittle <P.Wittle@anonymised.com>
wrote:
Hi Andrea,
So you were not able to reproduce it with the free data subset Ian was
referring to?
It should actually work in that case, but yes, maybe it just never happened
during testing.
Here:
https://github.com/geotools/geotools/blob/master/modules/library/render/src/main/java/org/geotools/renderer/lite/ZGroupLayer.java#L100
Mind, just removing the equality check will cause infinite loop under other
conditions, so if the issue is caused by two features in
different layers but same values, some re-architecting might be needed
Ing. Andrea Aime
@geowolf
Technical Lead
