[Geoserver-users] Looking for advise on architecture/setup to overlay 'transparent' OSM roads on aerial tiles
I’m new to GeoServer and have been trying to get some caching running with GeoWebCache, the demos worked out well but I’m a bit lost whether and how I can get my idea to work in the best way.
What I like to achieve is the following:
1.) Have a basemap with aerial pictures
2.) Have a layer with OSM roads, borders and names (all else transparent)
I Will be requesting the data from OpenLayers and CesiumJS.
The (layer acting as) basemap is available at a remote server and for performance reasons it would be great to cache the data temporarily at the local client (Windows 8.1 64b). Except from the URL it responds identical to the well known scheme used by Google Maps (example: http://mt.google.com/vt/lyrs=s&x=4&y=5&z=4 , only with a different URL before the first & of course :wink: ). Also same projection.
I Plan to use the osm-hybrid-carto style sheet (https://github.com/andrewharvey/osm-hybrid-carto/). See for an example http://tianjara.net/map#12/-33.9844/151.1798 (select an Imagery and the OSM Hybrid layer).
The idea is to load OSM data into a database and let GeoServer serve it out using two style sheets:
a.) osm-hybrid-carto - when the remote server is available, such the OSM data provides a transparent overlay of roads/names
b.) normal - when the remote server is not available, such that the OSM data provides a normal chart/map
Next to that I would like to have the GeoWebCache functionality cache the following:
a.) temporal aerial tiles from remote server - to limit load on the remote server and internet connection
b.) transparent OSM roads/borders overlay from local server
c.) full OSM map tiles from local server
OpenLayers and CesiumJS should just be able to load any of the discussed as layers and switch between them on the fly, but that’s the easiest bit…
My questions:
1.) Is my idea feasible with a single GeoServer instance
2.) How do I set up GeoWebCache to listen to requests from a client and fetch the aerial tiles from the TMS server
3.) How do I set up GWC to cache the OSM transparent and ‘full’ tiles at the same time, while also delivering the aerial tiles
4.) Whether I’m missing something essential
Hope someone can give me some help into the right direction :-).
Kim
Maybe I needed to add a little more info what I’d like to set up before someone can help and think along.
I’ll be using OpenLayers and CesiumJS to present the maps/layers.
1.) My basemap needs to be a normal OpenStreetMap map, only with a different style than standard
  • Should be possible to import using osm2pgsql, maybe better solutions available?
  • Plan to use PostgreSQL database on Windows 8.1 64b with PostGIS
    (- the ‘basemap’ may be delivered via a small cache managed by GeoWebCache)
2.) As overlay I need to cache the aerial tiles from the remote tile server
  • This is a normal overlay, tiles just build up on top of the base layer when they arrive
  • Should I run this from the same GeoServer instance, or would it be better to use a separate one or even use MapProxy (got the latter working already)
3.) Another layer needs to be ‘hybrid’, the aerial tiles (2) need to get the roads+names from the basemap
  • I Should be able to use the mentioned hybrid OSM stylesheet to have labels and roads/borders as transparent overlay
  • The labels/etc. should only be visible on top of the aerial tiles, in case the basemap is still visible for a specific tile, first that tile needs to have become an aerial tile first
  • Alternatively it may be better to combine aerial and OSM transparant tiles on the fly, not sure if this is possible in GeoServer though.
Hope a light can be shed whether this setup is possible, what I should avoid to do, or whether there are alternative solutions to my idea.
On Wed, Jan 21, 2015 at 5:31 PM, Kim Jansen <kim@anonymised.com5…> wrote:
My questions:
Kim
Hello Kim,
That is some project you have there!
First of all, everything is possible with geoserver and geowebcache.
It all depends on the size and scale of your project:
- How many users will you be serving?
- How big a geographic area will you provide?
A single machine easily becomes overloaded, don't expect lightning
fast performance..
2015-01-28 17:14 GMT+01:00 Kim Jansen <kim@anonymised.com>:
Maybe I needed to add a little more info what I'd like to set up before
I'll be using OpenLayers and CesiumJS to present the maps/layers.
style than standard
- Should be possible to import using osm2pgsql, maybe better solutions
available?
You can choose between a variety of importers; imposm and osm2pgsql
are solutions that shouldn't take to much time to set up. What
triggers me is "a different style than standard". As a cartographer, I
know that can be a huge time consumer. I have done a lot of SLD
styling myself and can tell you from experience, it keeps you
occupied. Are you really sure that is what you want to do yourself? Or
would getting an account at mapbox, cartodb or maybe
http://www.thunderforest.com/ solve your problems?
- Plan to use PostgreSQL database on Windows 8.1 64b with PostGIS
(- the 'basemap' may be delivered via a small cache managed by GeoWebCache)
Shouldn't be a problem, but depends on the geographical size of your
interest area.
- This is a normal overlay, tiles just build up on top of the base layer
when they arrive
- Should I run this from the same GeoServer instance, or would it be better
Again, this depends on the size of your project.
3.) Another layer needs to be 'hybrid', the aerial tiles (2) need to get the
- I Should be able to use the mentioned hybrid OSM stylesheet to have labels
- The labels/etc. should only be visible on top of the aerial tiles, in case
- Alternatively it may be better to combine aerial and OSM transparant tiles
On Wed, Jan 21, 2015 at 5:31 PM, Kim Jansen <kim@anonymised.com> wrote:
I'm new to GeoServer and have been trying to get some caching running with
GeoWebCache, the demos worked out well but I'm a bit lost whether and how I
Hybrid layer).
following:
as layers and switch between them on the fly, but that's the easiest bit...
My questions:
3.) How do I set up GWC to cache the OSM transparent and 'full' tiles at
4.) Whether I'm missing something essential
Kim
Dive into the World of Parallel Programming. The Go Parallel Website,
sponsored by Intel and developed in partnership with Slashdot Media, is your
hub for all things parallel software development, from weekly thought
leadership blogs to news, videos, case studies, tutorials and more. Take a
look and join the conversation now. http://goparallel.sourceforge.net/
Geoserver-users mailing list
Milo van der Linden
dogodigi
t: +31-6-16598808
Hi Milo,
Thanks for the reply, good news that it should be possible. I understand there might be performance things we need to take into account, but from the other hand my idea is probably not that spectacular.
Hope it’s possible to iron out the architecture a little and see if I can get a quick and dirty proof of concept with a small area up and running first. I’m new and have no clue on the amount of work involved and what to expect at all ;-).
I’ve commented in-line.
Kim
On Wed, Jan 28, 2015 at 5:39 PM, Milo van der Linden <milo@anonymised.com> wrote:
Hello Kim,
  • How many users will you be serving?
  • How big a geographic area will you provide?
A single machine easily becomes overloaded, don’t expect lightning
fast performance…
Basically what I have is that I like to have several ‘systems’ in the field with limited connectivity (intermittent connection, high latency and low bandwidth) that need access to map data for reference/information, not business critical stuff. The coverage that I need is worldwide and performance is the main reason I’m looking for a decent solution. Each system ideally stores around 150GB of ‘fixed’ aerial tiles to a reasonable zoom level, has a complete OSM database and maybe/optionally a temporary and small cache of Bing tiles that fills up the gap between the 150GB dataset and the close-up zoom levels.
The load on the GeoServer is quite limited I think, in most cases it would only the local user to the machine that requests data. There is a scenario where up to 25 users per system may request tiles, but this will never happen concurrently and each of the users will just have a normal profile of someone playing with a map on an iPad.
My best guess is that this should still be feasible even with a simple Core i3 and 8GB of RAM?
style than standard
    available?
are solutions that shouldn’t take to much time to set up. What
triggers me is “a different style than standard”. As a cartographer, I
I First want to get things running with the standard styles, and later on work with a cartographer (or existing stylesheet) to see if we can make it a little more visually attractive. All the available providers of nicely styled maps, or those that provide tools to ‘easily’ customise a map seem to be relying on an active internet connection for their service. And that’s just what’s not very available to me.
Shouldn’t be a problem, but depends on the geographical size of your
interest area.
I’m guessing I will be looking at 250-300GB of database size with OSM data given I need worldwide coverage. But again, my feeling is this is large is size, but the load will be relatively low.
    when they arrive
Hybrid layer).
following:
My questions:
Kim
Milo van der Linden
dogodigi
t: +31-6-16598808
Hello Kim,
Things are getting clearer. You are looking for an offline solution!
Get it. You may consider mapproxy as it is able to generate mbtiles,
you can then take the mbtiles datastore on the road. I can strongly
advise you to set up an online/offline syncing mechanism too.
Good luck!
Milo
2015-01-28 18:17 GMT+01:00 Kim Jansen <kim@anonymised.com>:
Hi Milo,
Hope it's possible to iron out the architecture a little and see if I can
first. I'm new and have no clue on the amount of work involved and what to
expect at all ;-).
I've commented in-line.
Kim
wrote:
Hello Kim,
fast performance..
Basically what I have is that I like to have several 'systems' in the field
performance is the main reason I'm looking for a decent solution. Each
system ideally stores around 150GB of 'fixed' aerial tiles to a reasonable
i3 and 8GB of RAM?
> different
> style than standard
> available?
styled maps, or those that provide tools to 'easily' customise a map seem to
be relying on an active internet connection for their service. And that's
just what's not very available to me.
> GeoWebCache)
interest area.
I'm guessing I will be looking at 250-300GB of database size with OSM data
> server
> when they arrive
> better
> already)
> the
> labels
> case
> to
> tiles
> avoid
>> Hi all,
>> with
>> how I
>> transparent)
>> the
>> identical to
>> OSM
>> Hybrid layer).
>> OSM
>> the
>> following:
>> remote
>> discussed
>> bit...
>> My questions:
>> at
>> Cheers,
>> Kim
> your
> a
> Geoserver-users@lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geoserver-users
Milo van der Linden
dogodigi
t: +31-6-16598808
Milo van der Linden
dogodigi
t: +31-6-16598808
Hi Milo,
You can consider it to be an offline solution indeed, although there is room for updates or more ‘detail’ when there is a connection available and the user likes to see aerial info in more detail. The thing is that I think GeoServer might just pack everything needed in one solution. Using MapProxy I would need to have a separate OSM server running on that machine and it feels like a less ‘neat’ approach.
Think I should just give it a go, sounds like there are no real caveats or issues with
1.) Get OSM data in PostgreSQL and have GeoServer serve it
2.) Set up the GeoWebCache functionality in GeoServer to cache from remote aerial tiles
3.) Set up another OSM layer with transparent tiles
4.) Combine the transparent OSM tiles with the remote aerial tiles
The only ‘uncertain’ thing for me right now is how to have GeoServer serve out the hybrid map (the transparent OSM info on top of and embedded with the aerial) instead of serving it as a separate layer.
Kim
On Wed, Jan 28, 2015 at 7:03 PM, Milo van der Linden <milo@anonymised.com> wrote:
Hello Kim,
Good luck!
Milo
Hi Milo,
expect at all ;-).
Kim
wrote:
Hello Kim,
fast performance…
i3 and 8GB of RAM?
different
style than standard
    available?
    GeoWebCache)
interest area.
server
    when they arrive
    better
    already)
the
    labels
    case
    to
    tiles
avoid
with
how I
transparent)
the
identical to
OSM
Hybrid layer).
OSM
the
following:
remote
discussed
bit…
My questions:
at
Kim
your
a
Milo van der Linden
dogodigi
t: +31-6-16598808
Milo van der Linden
dogodigi
t: +31-6-16598808
