Hallo,
I ve been using geoserver 1.6.5 for a while and all was fine. Some times
ago, I started to get this message when I call the map preview :
The following exception was thrown:
class javax.servlet.ServletException: javax.servlet.jsp.JspException:
No getter method for property: "EscapedFTNamespaceList[0]" of bean:
"mapPreviewForm"
class javax.servlet.jsp.JspException: No getter method for property:
"EscapedFTNamespaceList[0]" of bean: "mapPreviewForm"
Details:
javax.servlet.ServletException: javax.servlet.jsp.JspException: No getter
method for property: "EscapedFTNamespaceList[0]" of bean: "mapPreviewForm"
at
org.apache.jasper.runtime.PageContextImpl.doHandlePageException(PageContextImpl.java:850)
at
org.apache.jasper.runtime.PageContextImpl.handlePageException(PageContextImpl.java:779)
at
org.apache.jsp.WEB_002dINF.pages.mapPreview_jsp._jspService(mapPreview_jsp.java:870)
I have removed every piece of data to get rid of it (entities, styles,
coverages).
When I have no entity, I get an empty map preview list.
As soon as I add any entity, this message is back.
I have reloaded geoserver.war, I have replaced my data dir with the one
from the geoserver-1.6.5.war archive : I still get this message.
Is there any data anywhere else that I have forgotten ???
Help !!!!!!!!!!!! ............
(Embedded image moved to file: pic14688.jpg)
CONFIDENTIALITE : Ce message et les éventuelles pièces attachées sont
confidentiels. Si vous n'êtes pas dans la liste des destinataires, veuillez
informer l'expéditeur immédiatement et ne pas divulguer le contenu à une
tierce personne, ne pas l'utiliser pour quelque raison que ce soit, ne pas
stocker ou copier l'information qu'il contient sur un quelconque support.
CONFIDENTIALITY : This e-mail and any attachments are confidential and may
be privileged. If you are not a named recipient, please notify the sender
immediately and do not disclose the contents to another person, use it for
any purpose or store or copy the information in any medium.
