[Geoserver-users] map tile resolution
I am using geoserver to generate wms currently. and it gave me no problem at
all.
however when i try to use tilecache to generate the map image using the same
BBOX
value as what i use to generate wms in geoserver it returns me error message
as follows:
"couldn't calculate tile index for layer test4 from ([103.7109375,
1.2303741774326145, 103.88671875, 1.4061088354351594])"
I am using SRS=EPSG:4326 for the SRS value.
any idea on how to get the correct map image?
i read about set up the resolutions value in the conf file. but i have no
idea on how to calculate
the correct resolution
Thank you
Kencana
View this message in context: http://www.nabble.com/map-tile-resolution-tf4222269.html#a12011116
Hi Kenaca,
What client are you using? You must configure the client to request tiles at the resolutions you have configured tilecache to serve. Although there may be a way to configure tilecache to be "lenient"... not sure.
Have you seen this tutorial?
http://docs.codehaus.org/display/GEOSDOC/TileCache+Tutorial
-Justin
Kencana wrote:
all. however when i try to use tilecache to generate the map image using the same
BBOX value as what i use to generate wms in geoserver it returns me error message
as follows: "couldn't calculate tile index for layer test4 from ([103.7109375,
1.2303741774326145, 103.88671875, 1.4061088354351594])" I am using SRS=EPSG:4326 for the SRS value. any idea on how to get the correct map image? i read about set up the resolutions value in the conf file. but i have no
idea on how to calculate the correct resolution
Thank you
Regards, Kencana
Justin Deoliveira
The Open Planning Project
http://topp.openplans.org
Hi Justin,
thanks for the reply. right now i am trying to use google map
with tilecache and the geoserver as the wms server.
any idea on how to make it run perfectly?
or is there any other way to do the wms tile other than meta tile and
tilecache?
Thank you
Kencana
Justin Deoliveira-4 wrote:
Hi Kenaca,
not sure.
-Justin
Kencana wrote:
at
all.
same
BBOX
message
as follows:
Thank you
Kencana
Justin Deoliveira
Geoserver-users mailing list
View this message in context: http://www.nabble.com/map-tile-resolution-tf4222269.html#a12027959
Hi Kencana,
What you could do is use openlayers as the client. I am not sure if you familiar with it but its a tiling wms client. Setting it up with GeoServer and tilecache you should get a nice "tiled" result.
Doing a bit of research it appears it is possible to also use google as a base map and overlay geoserver wms layers on top of it. You may find this thread from the openlayers-dev list of interest.
http://openlayers.org/pipermail/dev/2007-July/000930.html
With a cool demo of it here:
http://openlayers.org/gallery/multiple.html
-Justin
Kencana wrote:
Hi Justin,
tilecache?
Thank you
Kencana
Hi Kenaca,
-Justin
Kencana wrote:
at
same
message
Thank you
Regards, Kencana
Justin Deoliveira
Justin Deoliveira
It is really boring to configure this coordinetes appropriately… I spent a lot of time to configure everything correctly in my application…
Are you using TileCache with OpenLayers? You have to configure openlayers’ map option accordingly with the tilecache configuration.
In the tilecache.cfg, I think that the bbox MUST be SQUARE. For example: bbox=10,50,14,54
14 - 10 = 54 - 50 = 4
This means that the TileCache will accept the following tile request BBOXes:
Zoom level nº 1:
10,50,14,54
Zoom level nº 2:
10,50,12,52 12,50,14,52
10,52,12,54 12,52,14,54
Zoom level nº 3:
10,50,11,51 11,50,12,51 12,50,13,51 13,50,14,51
10,51,11,52 11,51,12,52 12,51,13,52 13,51,14,52
10,52,11,53 11,52,12,53 12,52,13,53 13,52,14,53
10,53,11,54 11,53,12,54 12,53,13,54 13,53,14,54
And so on…
In this example, your map option in the OpenLayers should be something like:
var options = {
maxExtent: new OpenLayers.Bounds(10,50,14,54),
maxResolution: 4 / 256, //each tile has 256 x 256 pixels, so a tile, in the max zoom level, has 4 = 14-10 = 54-50
numZoomLevels: 20,
controls: [new OpenLayers.Control.MouseDefaults()]
var map = new OpenLayers.Map(‘map’, options);
And in the tilecache.cfg your layer would be something like:
[tc_ruas]
type=WMSLayer
layers=ns1:limite,ns1:rios,ns1:ruas,ns1:rodovias
url=http://localhost/geoserver_1_4_0/wms
extension=png
bbox=10,50,14,54
If you still get pink tiles, click with the right button with the mouse in a pink tile, and see int the URL the bbox that it is requesting.
Thats it…
Daniel
On 8/6/07, Kencana <bluesky_dyx@anonymised.com > wrote:
all.
BBOX
as follows:
“couldn’t calculate tile index for layer test4 from ([ 103.7109375,
1.2303741774326145, 103.88671875, 1.4061088354351594])”
Thank you
Kencana
