[Geoserver-users] Mapbox vector tile cache
Hello, wondering if anyone has used the integrated GWC much for vector tiles?
I've been trying to get it running but am experiencing some odd results. I'm
seeing requests return a MISS for vector tiles that work fine (HIT) if
requested as a png8. I'm seeding the cache for both formats in advance yet
only about 10% of my vector requests return HIT. No MISS Reason header is
provided in the response for the MISS tiles.
Running GS 2.11 on Tomcat 8.5.6.
Any ideas? Not really sure how to even troubleshoot this.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Mapbox-vector-tile-cache-tp5327585.html
The type of used data store (vector tiles in this case) per se should not have any impact
on the GWC number of hits / misses.
GWC will request from the data store the needed tiles, store them and try to map them
with future requests. If a request doesn't match any existing tiles then GWC will request
the needed tiles from the data store store them an answer the request.
So if I understand your issue correctly, you seeded the layer before for png8 format but
10% of the requests are a miss ?
The best way to troubleshot this issue is trying different combinations of requests and
try to understand if a particular format or other parameter is forcing a miss.
For example if using a different image format like JPEG did the miss happen ?
The used style is the same for both ?
Nuno Oliveira
Check out the vibrant tech community on one of the world's most
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
- Earning your support instead of buying it, but Ian Turton: http://www.ianturton.com/talks/foss4g.html#/
- The GeoServer user list posting guidelines: http://geoserver.org/comm/userlist-guidelines.html
Nuno Oliveira
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Nuno Miguel Carvalho Oliveira
@nmcoliveira
Software Engineer
Via di Montramito 3/A
  The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
Hey Nuno, if i seed the layer for png8 and request these tiles, i get a 100%
HIT on the cache for the requests. If i seed the same layer for the
mapbox-vector format I get about a 10% HIT on the cache. Apart from the
format value, the request query string is identical. I'm using the default
'line' style in both cases.
It does seem very strange.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Mapbox-vector-tile-cache-tp5327585p5327598.html
I just made a test with trunk GeoServer, I basically perform this request several times:
http://localhost:8075/geoserver/gwc/service/wmts?REQUEST=GetTile&SERVICE=WMTS&VERSION=1.0.0&LAYER=sf:AggregateGeoFeature&STYLE=&TILEMATRIX=EPSG:4326:6&TILEMATRIXSET=EPSG:4326&FORMAT=application/x-protobuf;type=mapbox-vector&TILECOL=78&TILEROW=7
and once the needed tiles are cached I always get an HIT (100% hit).
If you want to put a breakpoint the code responsible for updating the hits is this one:
https://github.com/nmco/geowebcache/blob/adf4f9ccf59a5124986093d8fa04471c5e6feee8/geowebcache/core/src/main/java/org/geowebcache/conveyor/ConveyorTile.java#L240-L244
So maybe you are hitting some strange corner case or a issue specific to your GS version.
That say I don't know much about the vector tiles format so maybe someone will have a better feedback.
If you don't get any more feedback, I would go ahead and open an issue with enough data and steps to reproduce it:
https://osgeo-org.atlassian.net/projects/GEOS/summary
Nuno Oliveira
Nuno Oliveira
@nmcoliveira
Software Engineer
Ah, i see two very different things on your request string. You're using the
WMTS service and addressing GWC directly. I was using WMS for my vector tile
requests and expecting the geoserver integration with geowebcache to handle
the cache lookup.
I've updated my requests to use the WMTS and directed them at
/gwc/service/wmts and things seem to be working better. Still some more
testing todo but it's looking promising!
Thanks Nuno
View this message in context: http://osgeo-org.1560.x6.nabble.com/Mapbox-vector-tile-cache-tp5327585p5327717.html
Had some time to pick this up again today and have found that it's the tile
seeding process that's causing me issues, or more accurately the use of
metatiling with vector tiles. Once the tiles are seeded with a metatileing
factor of 1x1 i get a 100% HIT on the cache as expected using WMTS. If i
leave Metatiling at the default 4x4 i get far fewer cached tiles (as
expected) and very few HITs to the cache.
For example, at zoom 10 with EPSG:900913:
Metatile 4x4 - cache seed generates 35 tiles for my layer
Metatile 1x1 - cache seed generates 589+ tiles (~35*4*4?)
Is this the expected behaviour? Have i missed something (again)? Is this a
bug?
It's not really an issue for me to run with the 1x1 metatiling but it does
slow the seeding process down significantly.
Thoughts?
View this message in context: http://osgeo-org.1560.x6.nabble.com/Mapbox-vector-tile-cache-tp5327585p5328202.html
Hi, Ben,
Metatiling doesn’t work with Vector Tiles. Metatiling, basically, has the WMS create an image 4* (in both directions) as large and then GWC breaks it into 16 smaller images. This helps with labelling.
You cannot (easily) cut up vector tiles, so you cannot do this with vector tiles (only with image tiles).
Dave
On Tue, Jul 18, 2017 at 1:02 AM, Ben Jerrim <BJerrim@anonymised.com> wrote:
Had some time to pick this up again today and have found that it’s the tile
seeding process that’s causing me issues, or more accurately the use of
Metatile 1x1 - cache seed generates 589+ tiles (~3544?)
bug?
It’s not really an issue for me to run with the 1x1 metatiling but it does
Thoughts?
Geoserver-users@anonymised.com.382…sourceforge.net
Ah! I didn’t think about that. So since meta tiling is enabled by default (4x4)
this means that for using vector tiles with GWC in the best conditions meta
tiling should deactivated (set to 1x1) ?
On 07/18/2017 06:13 PM, Dave Blasby wrote:
Hi, Ben,
Dave
bug?
Thoughts?
Geoserver-users@anonymised.comsourceforge.net
engaging tech sites, Slashdot.org! [http://sdm.link/slashdot](http://sdm.link/slashdot)
- Earning your support instead of buying it, but Ian Turton: [http://www.ianturton.com/talks/foss4g.html#/](http://www.ianturton.com/talks/foss4g.html#/)
- The GeoServer user list posting guidelines: [http://geoserver.org/comm/userlist-guidelines.html](http://geoserver.org/comm/userlist-guidelines.html)
[Geoserver-users@lists.sourceforge.net](mailto:Geoserver-users@lists.sourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geoserver-users](https://lists.sourceforge.net/lists/listinfo/geoserver-users)
Nuno Oliveira
GeoServer Professional Services from the experts! Visit [http://goo.gl/it488V](http://goo.gl/it488V) for more information.
@nmcoliveira
Software Engineer
[http://www.geo-solutions.it](http://www.geo-solutions.it)
[http://twitter.com/geosolutions_it](http://twitter.com/geosolutions_it)
I think so - metatiling doesn’t make any sense for VTs. I thought it was automatically disabled…
Dave
On Tue, Jul 18, 2017 at 11:12 AM, Nuno Oliveira <nuno.oliveira@anonymised.com> wrote:
Hi, Ben,
Dave
[Geoserver-users@anonymised.com.382...sourceforge.net](mailto:Geoserver-users@lists.sourceforge.net)
Nuno Oliveira
@nmcoliveira
Software Engineer
bug?
Thoughts?
Geoserver-users@anonymised.comrge.net
Thanks guys... that took a while to understand!
Hopefully this thread helps the next person.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Mapbox-vector-tile-cache-tp5327585p5328321.html
I think we should consider this a bug. If metatiling doesn’t apply to Vector Tiles under any circumstances then it shouldn’t effect it.
On Tue, Jul 18, 2017 at 10:08 PM, Ben Jerrim <BJerrim@anonymised.com> wrote:
Thanks guys… that took a while to understand!
Jason Newmoyer
Newmoyer Geospatial Solutions
843.606.0424
jason@anonymised.com
Agreed. Can anyone open a bug report?
Jason Newmoyer
843.606.0424
+1
Issue created: https://osgeo-org.atlassian.net/browse/GEOS-8228
Jason Newmoyer
843.606.0424
Nuno Oliveira
@nmcoliveira
Software Engineer
