Which version are you talking about? We plan to keep the tasmania demos there.
Brent Owens
(The Open Planning Project)
Cameron Shorter wrote:
Hi geoserver people,
We have been doing final tests on Mapbuilder before our next minor release and it seems that the default install of geoserver we test against doesn't contain our demo data.
In particular, we are missing geoserver/data/featureTypes/tasmania_*/* shapfiles which means mapbuilder's WFS-T demo doesn't work with the default geoserver any more.
It seems that a number of the demos at http://localhost:8080/geoserver/demo.do don't work either.
And what are your future plans with regards to demos and data?
Can we get the Tasmania shapefiles included in the Geoserver release again?
We are holding off the Mapbuilder release until we get an understanding of what the plans are for Geoserver.
I actually found the same problem in 1.3.2 demos are not working anymore mainly because tasmania shapefiles are not there.
I download the war file and deploy it on tomcat on MacOS. I could not try the .exe version for windows, maybe they are still there.
Is it a packaging problem?
Gerald
there.
Brent Owens
Using Tomcat but need to do more? Need to support web services, security?
Get stuff done quickly with pre-integrated technology to make your job easier
Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642
Geoserver-users mailing list
Oh, they might not be in the war version. Download the binary version and copy the appropriate files over.
I might put up a new war with the taz files in it if you guys want.
Brent Owens
Gerald
there.
Brent Owens
In particular, we are missing geoserver/data/featureTypes/ tasmania_*/*
http://sel.as-us.falkag.net/sel? cmd=lnk&kid=120709&bid=263057&dat=121642
Oops sorry, forgot to mention version.
I noticed the problem in 1.3.2 and Mike reported that we had the same problem in 1.3.1.
If you are planning to re-instate the tasmania demos, when do you plan to make another release?
We will need to update our documentation to explain the issue.
Brent Owens
Cameron Shorter
http://cameron.shorter.net
Yes,
I only tested the .war file - which is how we recommend deploying a mapbuilder/geoserver WFS-T settup.
Another release would be great. If you can deploy within the next day or so, then we will delay our release till you are finished.
Brent Owens
Gerald
there.
Brent Owens
mapbuilder-devel mailing list
mapbuilder-devel@lists.sourceforge.net
https://lists.sourceforge.net/lists/listinfo/mapbuilder-devel
Cameron Shorter
I will put up a new war with the files in it cameron. I might send it your way first to double check everything is in order though.
Brent Owens
Yes,
Brent Owens
Gerald
there.
Brent Owens
Hi Brent and co,
I've just downloaded the geoserver 1.4.0M1 .war release and the demo
shapefiles seem to be missing again.
On 7/8/06, Cameron Shorter <cameron.shorter@anonymised.com> wrote:
Yes,
> Brent Owens
>>Gerald
>>>demos
>>>there.
>>>Brent Owens
>>>>tasmania_*/*
>>>>release again?
>>>>understanding
>>>security?
>>>job easier
>>>Geronimo
>>>_______________________________________________
>>>Geoserver-users@lists.sourceforge.net
>>>https://lists.sourceforge.net/lists/listinfo/geoserver-users
Cameron Shorter
Cameron Shorter
Yep they are missing in this version. They are definitely going to be included in all future releases.
Brent Owens
Hi Brent and co,
Yes,
> Brent Owens
>>Gerald
>>>demos
>>>there.
>>>Brent Owens
>>>>tasmania_*/*
>>>>release again?
>>>>understanding
>>>security?
>>>job easier
>>>Geronimo
Cameron Shorter
What demo shapefiles are we referring to? I moved some of the mb and
demo stuff around in order to work with both versions of the data
directory. But its quite possible they got missed.
-Justin
Brent Owens
Hi Brent and co,
Yes,
Brent Owens
Gerald
demos
there.
Brent Owens
tasmania_*/*
release again?
understanding
security?
job easier
Geronimo
security?
job easier
Geronimo
security?
job easier
Geronimo
Cameron Shorter
!DSPAM:1004,44ef0fdc119878365517736!
Justin Deoliveira
jdeolive@anonymised.com
The missing demo files that Mapbuilder uses are in:
geoserver\data\featureTypes\tasmania_cities
-Justin
Brent Owens
Hi Brent and co,
Yes,
Brent Owens
Gerald
demos
there.
Brent Owens
tasmania_*/*
release again?
understanding
security?
job easier
Geronimo
security?
job easier
Geronimo
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642 _______________________________________________
security?
job easier
Geronimo
Cameron Shorter
Cameron Shorter
