[Geoserver-users] [Mapbuilder-users] geoserver online - how
Stefano,
I'm cc'ing your message to geoserver-users. I assume you installed the standalone build of geoserver, which installs a jetty servlet container. This can be configured to use an AJP13 connector from which your Web Server (IIS as far as I can tell from looking at your site) can access it.
You might want to read the following resources:
    * http://www.atlassian.com/software/jira/docs/latest/iisintegration.html
      explains how to connect a servlet container (in this case tomcat,
      but with jetty it's the same procedure) to MS IIS.
    * http://docs.codehaus.org/display/JETTY/Configuring+AJP13+Using+mod_jk
      explains how to configure jetty to use the AJP13 connector.
Andreas.
Stefano Gambini wrote:
I have installed geoserver as localhost and built my interactive maps in there. All is working fine. I'd like to make them, and their functionalities, visible from my domain (www.geosisconsulting.eu). How can i do it? By installing the whole geoserver (and mapbuilder) to the root of my domain? I've actually tried, but doesn't work (http://www.geosisconsulting.eu/geoserver/welcome.do)
thanks
