[Geoserver-users] Mapfish and Tile services
Hi list,
I just wanted to check something before I report it as a bug (I suspect it is, but best to check).
I’m trying to use MapFish to create a pdf. The baselayer is coming from an external TileMapService.
While my web-browser can access this TMS, the web-server itself cannot (thus MapFish can’t render that layer).
The problem is - the error GeoServer console is giving is implying that the TMS URL itself is at fault:
28 Jan 12:40:49 ERROR [org.mapfish.print.servlet.BaseMapServlet] - Error while generating PDF
org.mapfish.print.InvalidJsonValueException: spec.layers[0].baseURL has an invalid value: http://www.osmgb.org.uk/ogc/tms27700/ (spec.layers[0].baseURL has an invalid value: http://www.osmgb.org.uk/ogc/tms27700/)
at org.mapfish.print.map.readers.HTTPMapReader.checkSecurity(HTTPMapReader.java:64)
at org.mapfish.print.map.readers.HTTPMapReader.(HTTPMapReader.java:55)
at org.mapfish.print.map.readers.TileableMapReader.(TileableMapReader.java:40)
at org.mapfish.print.map.readers.TmsMapReader.(TmsMapReader.java:42)
at org.mapfish.print.map.readers.TmsMapReader.create(TmsMapReader.java:86)
Has anyone else had any problems getting MapFish to serve a OpenLayers TMS? Or is this because my server can’t get to that URL (in which case, it would normally time out so… ?)
If someone wants to test this, there’s also a public web-mercator TMS at the same address; more information here: http://www.osmgb.org.uk/osm-gb-wiki/index.php/Tile_Service
Jonathan
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
Have you added the tile service to the whitelist in the printing config.yaml?
On Mon, Jan 28, 2013 at 7:47 AM, Jonathan Moules <jonathanmoules@anonymised.com> wrote:
Hi list,
Jonathan
Master Visual Studio, SharePoint, SQL, ASP.NET, C# 2012, HTML5, CSS,
MVC, Windows 8 Apps, JavaScript and much more. Keep your skills current
with LearnDevNow - 3,200 step-by-step video tutorials by Microsoft
MVPs and experts. ON SALE this month only – learn more at:
http://p.sf.net/sfu/learnnow-d2d
Geoserver-users mailing list
Hi David,
Yup, that fixed that that problem (not what I expected given the error though).
However, now that I’ve added it, I’m getting:
28 Jan 15:37:19 ERROR [org.mapfish.print.servlet.BaseMapServlet] - Error while generating PDF
java.lang.StringIndexOutOfBoundsException: String index out of range: -1
at java.lang.String.substring(Unknown Source)
at org.mapfish.print.map.readers.TmsMapReader.(TmsMapReader.java:48)
at org.mapfish.print.map.readers.MapReader.create(MapReader.java:58)
at org.mapfish.print.map.MapChunkDrawer.renderImpl(MapChunkDrawer.java:98)
Again, the server can’t actually access that layer itself, but I’d expect a timeout (and/or just a blank background) which doesn’t seem to be what I’m getting.
Any thoughts?
Jonathan
On Mon, Jan 28, 2013 at 7:47 AM, Jonathan Moules <jonathanmoules@anonymised.com…4942…> wrote:
Hi list,
Jonathan
