[Geoserver-users] MapPreviewPage errors
Hi!
I have a doubt about some log messages from geoserver. The version I’m running is 2.2.5 (old, I know).
There are 3 installations with this version, running in Apache Tomcat 7.0.35.
Two of them are quite normal, running in a perfect state.
One of them is throwing some WARN messages in log repeatedly right after start. In a few minutes, geoserver log files rotates at a size of 11M each.
For coincidence or not, this instalation is very slow lately.
Does anyone have a clue if these messages are related to the performance problem? And what are they about?
Sorry, I know this is an old version of geoserver, and that I have other installations in order, but this is my main development environment.
Oh! I also tried install a new tomcat and a new geoserver.war deploy (same versions) but the messages were still there, infinitely repeating
The WARN messages are bellow!
2014-02-04 15:39:08,124 WARN [geoserver.web] - Unable to find property: ‘format.wms.image/png; mode=8bit’ for component: [class=org.geoserver.web.demo.MapPreviewPage]
2014-02-04 15:39:08,124 WARN [geoserver.web] - Unable to find property: ‘format.wms.application/vnd.google-earth.kmz xml’ for component: [class=org.geoserver.web.demo.MapPreviewPage]
2014-02-04 15:39:08,124 WARN [geoserver.web] - Unable to find property: ‘format.wms.application/vnd.google-earth.kmz’ for component: [class=org.geoserver.web.demo.MapPreviewPage]
2014-02-04 15:39:08,126 WARN [geoserver.web] - Unable to find property: ‘format.wms.kmz’ for component: [class=org.geoserver.web.demo.MapPreviewPage]
2014-02-04 15:39:08,126 WARN [geoserver.web] - Unable to find property: ‘format.wms.openlayers’ for component: [class=org.geoserver.web.demo.MapPreviewPage]
2014-02-04 15:39:08,126 WARN [geoserver.web] - Unable to find property: ‘format.wms.text/html’ for component: [class=org.geoserver.web.demo.MapPreviewPage]
2014-02-04 15:39:08,127 WARN [geoserver.web] - Unable to find property: ‘format.wms.atom’ for component: [class=org.geoserver.web.demo.MapPreviewPage]
2014-02-04 15:39:08,127 WARN [geoserver.web] - Unable to find property: ‘format.wms.application/atom xml’ for component: [class=org.geoserver.web.demo.MapPreviewPage]
2014-02-04 15:39:08,127 WARN [geoserver.web] - Unable to find property: ‘format.wms.application/xml’ for component: [class=org.geoserver.web.demo.MapPreviewPage]
2014-02-04 15:39:08,128 WARN [geoserver.web] - Unable to find property: ‘format.wms.image/svg’ for component: [class=org.geoserver.web.demo.MapPreviewPage]
2014-02-04 15:39:08,128 WARN [geoserver.web] - Unable to find property: ‘format.wms.image/svg xml’ for component: [class=org.geoserver.web.demo.MapPreviewPage]
2014-02-04 15:39:08,133 WARN [geoserver.web] - Unable to find property: ‘format.wfs.application/json’ for component: [class=org.geoserver.web.demo.MapPreviewPage]
2014-02-04 15:39:08,134 WARN [geoserver.web] - Unable to find property: ‘format.wfs.application/json’ for component: [class=org.geoserver.web.demo.MapPreviewPage]
2014-02-04 15:39:08,153 WARN [geoserver.web] - Unable to find property: ‘format.wms.image/png; mode=8bit’ for component: [class=org.geoserver.web.demo.MapPreviewPage]
2014-02-04 15:39:08,153 WARN [geoserver.web] - Unable to find property: ‘format.wms.application/vnd.google-earth.kmz xml’ for component: [class=org.geoserver.web.demo.MapPreviewPage]
2014-02-04 15:39:08,153 WARN [geoserver.web] - Unable to find property: ‘format.wms.application/vnd.google-earth.kmz’ for component: [class=org.geoserver.web.demo.MapPreviewPage]
2014-02-04 15:39:08,153 WARN [geoserver.web] - Unable to find property: ‘format.wms.kmz’ for component: [class=org.geoserver.web.demo.MapPreviewPage]
2014-02-04 15:39:08,154 WARN [geoserver.web] - Unable to find property: ‘format.wms.openlayers’ for component: [class=org.geoserver.web.demo.MapPreviewPage]
2014-02-04 15:39:08,154 WARN [geoserver.web] - Unable to find property: ‘format.wms.text/html’ for component: [class=org.geoserver.web.demo.MapPreviewPage]
2014-02-04 15:39:08,154 WARN [geoserver.web] - Unable to find property: ‘format.wms.atom’ for component: [class=org.geoserver.web.demo.MapPreviewPage]
2014-02-04 15:39:08,154 WARN [geoserver.web] - Unable to find property: ‘format.wms.application/atom xml’ for component: [class=org.geoserver.web.demo.MapPreviewPage]
2014-02-04 15:39:08,155 WARN [geoserver.web] - Unable to find property: ‘format.wms.application/xml’ for component: [class=org.geoserver.web.demo.MapPreviewPage]
2014-02-04 15:39:08,155 WARN [geoserver.web] - Unable to find property: ‘format.wms.image/svg’ for component: [class=org.geoserver.web.demo.MapPreviewPage]
2014-02-04 15:39:08,155 WARN [geoserver.web] - Unable to find property: ‘format.wms.image/svg xml’ for component: [class=org.geoserver.web.demo.MapPreviewPage]
2014-02-04 15:39:08,158 WARN [geoserver.web] - Unable to find property: ‘format.wfs.application/json’ for component: [class=org.geoserver.web.demo.MapPreviewPage]
2014-02-04 15:39:08,159 WARN [geoserver.web] - Unable to find property: ‘format.wfs.application/json’ for component: [class=org.geoserver.web.demo.MapPreviewPage]
Rodrigo C. Antonialli
Rio Claro - SP - Brasil
LinkedIn: http://www.linkedin.com/in/rcantonialli
Contato: (19) 98136-2347
rcantonialli@anonymised.com
Skype: rc_antonialli
Hi again!
Part of the problem solved… At least, the warn messages are not shown infinitely anymore.
I’ve done a diff between my current geoserver data dir and the original one.
Then I copied the files that were different from original.
Most of the files were filters config.xml (and I don’t know why they changed… probably something stupid I did… o.O)
Now the warn messages are shown only when the MapPreview is opened.
On Tue, Feb 4, 2014 at 4:13 PM, Rodrigo Antonialli <rcantonialli@anonymised.com> wrote:
Hi!
Hi Andrea,
Any thoughts on this? I note my own logs have this too, but it’s not in the spreadsheet you created; I guess I missed it somehow.
Is this something we can add to that ticket?
Jonathan
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
On 5 February 2014 10:53, Rodrigo Antonialli <rcantonialli@anonymised.com> wrote:
Hi again!
Managing the Performance of Cloud-Based Applications
Take advantage of what the Cloud has to offer - Avoid Common Pitfalls.
Read the Whitepaper.
http://pubads.g.doubleclick.net/gampad/clk?id=121051231&iu=/4140/ostg.clktrk
Geoserver-users mailing list
Hi!
On Fri, Feb 7, 2014 at 2:39 PM, Jonathan Moules <
jonathanmoules@anonymised.com> wrote:
Hi Andrea,
Any thoughts on this? I note my own logs have this too, but it's not in
Yep
== Our support, Your Success! Visit http://opensdi.geo-solutions.it for
more information ==
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
