[Geoserver-users] MapRequest filters for range of values on raster coverage stores
I have a requirement to set thresholds on values to display on a map request to a NETCDF backed coverage store. For example, I have a layer for surface temperature, and they want to be able to only display areas on the map that are between 25 and 30 centigrade. Is there a way to achieve this with Geoserver? I’ve attempted to use CQL_FILTER but this only results in errors like “Error rendering coverage on the fast path” so I think that must not be the correct manner to produce filtered results. Any advice on how to achieve this requirement would be greatly appreciated.
Thanks!
Steve Ferguson
Hi Steve,
are you talking about simple rendering or do you also need this to be respected by a getFeatureInfo call?
In the first case a solution can be setting up an a SLD with a colorMap, setting opacity = 0 for values outside your range.
http://docs.geoserver.org/latest/en/user/styling/sld-reference/rastersymbolizer.html#colormap
Let’s if other devs chime in with additional feedbacks.
Daniele
On Thu, Oct 29, 2015 at 9:35 PM, Ferguson, Steve -FS <sferguson@anonymised.com> wrote:
Thanks!
Steve Ferguson
Geoserver-users mailing list
Ing. Daniele Romagnoli
Senior Software Engineer
Via Poggio alle Viti 1187
Daniele,
Thanks for the response. I am talking about simple rendering. I have been using a ramp color map with just a few ColorMapEntry s with nice results. To do something like you suggest I suppose I would have to create many more ColorMapEntry items each with an ENV based opacity, which I think might become cumbersome, particularly for values with a broad range. Is there a way to use a CQL_FILTER that will only render values that are in range?
Thanks!
Steve
Hi Steve,
Daniele
On Thu, Oct 29, 2015 at 9:35 PM, Ferguson, Steve -FS <sferguson@…102…> wrote:
Thanks!
Steve Ferguson
There is no way to filter the pixel contents, nope. CQL_Filter can be used against rasters, but it has a different
meaning, it’s used to locate a specific mosaic slice by filtering the mosaic index.
The functionality you are interested into would be sure worth implementing, see this page for getting new
features in GeoServer: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
Mind, in recent version of GeoServer it is possible to pass down env variables into the color map, making the
filtering dynamic (it’s called CQL, and it is, but the only thing you can actually use in there is env variables passed
via the env parameter, it has no access to the current pixel value either):
http://docs.geoserver.org/stable/en/user/styling/sld-reference/rastersymbolizer.html#cql-expressions
On Fri, Oct 30, 2015 at 1:59 PM, Ferguson, Steve -FS <sferguson@anonymised.com> wrote:
Daniele,
Thanks!
Steve
From: dany.geotools@anonymised.com [mailto:dany.geotools@anonymised.com] On Behalf Of Daniele Romagnoli
Sent: Friday, October 30, 2015 3:20 AM
To: Ferguson, Steve -FS
Subject: Re: [Geoserver-users] MapRequest filters for range of values on raster coverage stores
Hi Steve,
Daniele
On Thu, Oct 29, 2015 at 9:35 PM, Ferguson, Steve -FS <sferguson@anonymised.com102…> wrote:
Thanks!
Steve Ferguson
Ing. Andrea Aime
@geowolf
Technical Lead
mob: +39 339 8844549
