On Fri, Sep 11, 2015 at 2:48 PM, benedeksimo <universitas87@anonymised.com>
wrote:
In this very useful blog post it can be seen that the Marlin renderer is
giving better performance with Geoserver. In the post version 0.3 is
mentioned. Now it has version 0.7.
Is this newer version is safe to use with Geoserver 2.6.4 or later? Or
which
version one should choose?
GeoServer does not have a particular dependency on Marlin, you can just
plug it
in the virtual machine.
So it should be compatible with any version of Marlin, although it's not
officially
tested with any
Try it out, and if there is any issue, report to the marlin mailing lists.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
