Hi All,
I have 213 data store and trying to publish the data but geoserver fail to
open the admin page. is there any limit in creating data stores and
publishing data.
What could be the possible reason?
Santosh
View this message in context: http://osgeo-org.1560.x6.nabble.com/max-data-store-limit-tp5052859.html
Hi Santosh,
Can you give us a general break-down of the types of data-stores?
Also, what does the GeoServer log say when you try and access the admin page? If possible can you change the logging level to GeoTools Developer?
Jonathan
On 13 May 2013 11:15, santosh <santosh@anonymised.com> wrote:
Hi All,
publishing data.
Santosh
Learn Graph Databases - Download FREE O’Reilly Book
“Graph Databases” is the definitive new guide to graph databases and
their applications. This 200-page book is written by three acclaimed
leaders in the field. The early access version is available now.
Download your free book today! http://p.sf.net/sfu/neotech_d2d_may
Geoserver-users mailing list
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
