[Geoserver-users] MaxFeatures/Count+Startindex broken?
I am getting results which look faulty to me from my local Geoserver 2.5 and also from demo.opengeo.org which is running some 2.4 snapshot version.
http://demo.opengeo.org/geoserver/wfs?service=wfs&version=2.0.0&request=getfeature&typename=topp:states&count=2&startindex=30
http://demo.opengeo.org/geoserver/wfs?service=wfs&version=1.0.0&request=getfeature&typename=topp:states&STARTINDEX=20&MaxFeatures=2
First fid with startindex=30 should be states.31 and with startindex=20 states.21, shouldn't? I am getting first features as states.37 and states.28, respectively.
-Jukka Rahkonen-
On Fri, May 2, 2014 at 2:31 PM, Rahkonen Jukka (Tike) <
jukka.rahkonen@anonymised.com> wrote:
Hi Jukka,
first an observation, in general you cannot assume you will get the
features in any particular particular order unless you apply an explicit
sort by clause.
That said, let me try a local request with a startindex=0:
http://localhost:8080/geoserver/wfs?service=wfs&version=2.0.0&request=getfeature&typename=topp:states&propertyname=STATE_NAME&startIndex=0
The result is that I get the features sorted by fid, so I have states.1,
states.11, states.12, ... states.20, states.21, ... states.30, states.31
and so on.
And if I add a startIndex > 0, then I get the data properly shifted.
Order and position of returned features is not changing if I modify the
version.
Long story short, it seems it's working as it should
Meet us at GEO Business 2014! in London! Visit http://goo.gl/fES3aK
for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
OK, with the startindex values I did not see that startindex is changing the sorting to alphabetical. Plain GetFeature with maxFeatures returns features in order states.1, states.2, states.3 but adding startindex is really changing the order into states.1, states.10, states.11.
I perhaps agree that current behaviour is acceptable bu it is not logical, and Geoserver users must know that they must load data in pages always with startindex because startindex=0 does not return the sama data than if parameter is not used at all.
It looks like this behaviour has changed since 2012 and Geoserver 2.1.3 and the example used in this blog does not work any more in a similar way http://www.geo-solutions.it/blog/wfs-for-the-masses-adding-support-for-paging-and-sorting-in-geoserver/.
-Jukka Rahkonen-
On Fri, May 2, 2014 at 2:31 PM, Rahkonen Jukka (Tike) <jukka.rahkonen@anonymised.com> wrote:
First fid with startindex=30 should be states.31 and with startindex=20 states.21, shouldn’t? I am getting first features as states.37 and states.28, respectively.
Hi Jukka,
first an observation, in general you cannot assume you will get the features in any particular particular order unless you apply an explicit sort by clause.
The result is that I get the features sorted by fid, so I have states.1, states.11, states.12, … states.20, states.21, … states.30, states.31 and so on.
Order and position of returned features is not changing if I modify the version.
Long story short, it seems it’s working as it should
Ing. Andrea Aime
@geowolf
Technical Lead
On Sun, May 4, 2014 at 1:55 PM, Rahkonen Jukka (Tike) <
It may be counter-intuitive, I agree, but forcing a sort is the only way to
get stable paging across all data sources.
But of course, we initiate that only if the client shows an intent to page,
without a startIndex we avoid it to get better performance.
Ing. Andrea Aime
@geowolf
Technical Lead
