[Geoserver-users] Maximum and minimum coverage evaluetion using org.geotools.coverage.processing.OperationJAI.Extrema
Hi list,
I’m trying to built a WPS to evaluate the basic statistic information of coverage data usign org.geotools.coverage.processing.OperationJAI.Extrema but minimum value is coincident with noData value (i.e. -9999, correctly reported as nodata by gdalinfo). Is there some method, in this class, to obtain the right minimum and maximum?
Thx
Luigi Marotta
IT Specialist - Ariespace s.r.l - Spin off Company
Università degli Studi di Napoli “Federico II”
Centro Direzionale IS. A3
80143 - Napoli - Italy
tel.: (+39) 08119564282
fax: (+39) 08119564223
mob.: (+39) 3478836273
skypecontact: live:luigi.marotta
PRIVACY
Le informazioni contenute in questo messaggio sono riservate e confidenziali. Il loro utilizzo e’ consentito esclusivamente al destinatario del messaggio, per le finalità indicate nel messaggio stesso. Qualora Lei non fosse la persona a cui il presente messaggio è destinato, La invitiamo ad eliminarlo dal Suo Sistema ed a distruggere le varie copie o stampe, dandocene gentilmente comunicazione. Ogni utilizzo improprio e’ contrario ai principi del D.lgs 196/03 e alla legislazione europea (Direttiva 2002/58/CE).
The information in this e-mail is intended for the named recipients only. It may contain privileged and confidential information. If you have received this communication in error, any use, copying or dissemination of its contents is strictly prohibited. Please erase all copies of the message along with any included attachments and notify the sender immediately.
On Thu, Feb 6, 2014 at 4:29 PM, Luigi Marotta
<luigi.marotta@anonymised.com>wrote:
Hi list,
         I'm trying to built a WPS to evaluate the basic statistic
I don't think so, JAI does not have a concept of nodata
== Our support, Your Success! Visit http://opensdi.geo-solutions.it for
more information ==
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
And you know some alternative way?
thx
Luigi Marotta
PRIVACY
2014-02-06 Andrea Aime <andrea.aime@anonymised.com>:
On Thu, Feb 6, 2014 at 4:29 PM, Luigi Marotta <luigi.marotta@anonymised.com> wrote:
Hi list,
I don’t think so, JAI does not have a concept of nodata
== Our support, Your Success! Visit http://opensdi.geo-solutions.it for more information ==
Ing. Andrea Aime
@geowolf
Technical Lead
On Thu, Feb 6, 2014 at 5:36 PM, Luigi Marotta
Implement your own JAI operation that is NODATA aware. Yes, this requires
coding :slight_smile:
more information ==
Ing. Andrea Aime
@geowolf
Technical Lead
Thx
Luigi Marotta
PRIVACY
On Thu, Feb 6, 2014 at 5:36 PM, Luigi Marotta <luigi.marotta@anonymised.com> wrote:
Implement your own JAI operation that is NODATA aware. Yes, this requires coding :slight_smile:
Ing. Andrea Aime
@geowolf
Technical Lead
Ciao Luigi,
Going by memore, there si a zonal stats operation that could be instructed to’ take nodata values out of the computation.
I am putting One of our guys in the loop sa he will have more information.
Simone.
Luigi Marotta
PRIVACY
2014-02-06 Andrea Aime andrea.aime@anonymised.com:
On Thu, Feb 6, 2014 at 5:36 PM, Luigi Marotta luigi.marotta@anonymised.com wrote:
Ing. Andrea Aime
@geowolf
Technical Lead
Hi Luigi,
yesterday I was writing you this reply but there was a blackout in the whole building so… I have seen other guys already suggested something.
Sending anyway my email for further info, just in case…
The GT Extrema operation is based on JAI Extrema op which doesn’t support NoData so it doesn’t know that -9999 is a noData and therefore it returns that value as the minimum.
A workaround you may try is providing a ROI (Region Of Interest) based on a threshold value to exclude some regions of the input image from the computations.
http://download.java.net/media/jai/javadoc/1.1.3/jai-apidocs/javax/media/jai/operator/ExtremaDescriptor.html
You can create a ROI on top of the input RenderedImage using a threshold value. Only pixels inside the ROI will be taken into account by statistics.
http://docs.oracle.com/cd/E17802_01/products/products/java-media/jai/forDevelopers/jai-apidocs/javax/media/jai/ROI.html#ROI%28java.awt.image.RenderedImage,%20int%29
As an instance, if -9999 is the minimum “bad” value and you know that all your values are >= A (Where A > -9999), you can do
ROI roi = new ROI(inputRenderedImage, A);
OperationJAI op=new OperationJAI(“Extrema”);
ParameterValueGroup params = op.getParameters();
params.parameter(“roi”).setValue(roi);
I know, that isn’t the optimal solution (especially for the ROI computation) but it may help.
Daniele
Ing. Daniele Romagnoli
Senior Software Engineer
Hi list,
Thx
Luigi Marotta
PRIVACY
Managing the Performance of Cloud-Based Applications
Take advantage of what the Cloud has to offer - Avoid Common Pitfalls.
Read the Whitepaper.
http://pubads.g.doubleclick.net/gampad/clk?id=121051231&iu=/4140/ostg.clktrk
Geoserver-users mailing list
Hi Luigi,
you can use the “ZonalStats” operation. It is an OperationJAI subclass which uses the JaiTools ZonalStatistics operation.
With this class you can calculate the Minimum and Maximum of the image and setting the right nodata value.
This class is located in the GeoTools module “gt-coverage” together with other operations (see the link: https://github.com/geotools/geotools/tree/master/modules/library/coverage/src/main/java/org/geotools/coverage/processing/operation).
The JaiTools ZonalStats documentation can be found here: http://jaitools.org/docs/jaitools/stable/apidocs/
Hope this will help.
Nicola
2014-02-07 Daniele Romagnoli <daniele.romagnoli@anonymised.com>:
Hi Luigi,
Daniele
Hi list,
Thx
Luigi Marotta
PRIVACY
Geoserver-users@anonymised.com.net
Ing. Nicola Lagormarsini
Junior Software Engineer
