[Geoserver-users] mbstyle multi rules
Hi guys,
Is there a way to create a style in mbstyle format for a layer with differents rules ?
There is only one paint per layer so i was expecting something like that could work but it doesn’t, “Invalid SLD”.
The idea is to have 2 layers with 2 differents filters and paints…
“version”: 8,
“name”: “violet polygon”,
“layers”: [
“id”: “violet polygon”,
“type”: “fill”,
“filter”: [“>”, “IDN3”, 710],
“paint”: {
“fill-color”: “#3300ff”,
“fill-outline-color”:“#000000
“id”: “red polygon”,
“type”: “fill”,
“filter”: [“<”, “IDN3”, 710],
“paint”: {
“fill-color”: “#aa0000”,
Maybe it’s not possible with the current implementation ?
Thanks for hints
camptocamp
INNOVATIVE SOLUTIONS
BY OPEN SOURCE EXPERTS
Florent Gravin
Technical Leader - Architect
+33 4 58 48 20 36
You may wish to try with function stops for the fill-color.
Boundless Server had some documentation on how much of the mapbox style expression syntax was implemented, the filter syntax you are describing is now deprecated in the specticication.
Still I expected that to work, are you in position to write a test case and patch? I know the codebase enough to review.
I am quite keen on the mbstyle technology and would like to see the functionality become a formal extension if we can identify enough interested parties for maintenance and improvements.
Jody Garnett
Hi Jody,
Thanks for the answer, the syntax works well if you just have one layer, this works fine:
“version”: 8,
“layers”: [
“type”: “fill”,
“paint”: {
My concern is that I want multi rules, some US states displayed in green, and others in red for instance, and I am not sure the mbstyle extension handles it, and if yes, what it the correct syntax.
The document only shows examples with one rule.
I think we can do something yes
I totally agree, we’ll try to push a bit on it if we manage to make it work for multi rules styles layer.
Thanks for support Jody
camptocamp
Florent Gravin
+33 4 58 48 20 36
(Resending this to the user list as delivery failed, if you already saw my reply disregard this)
Hi Florent,
I took a look at your style, and the two layers each are missing the “source-layer” attribute.
MBStyle is able to apply to multiple GeoServer layers, so when the style has more than one layer, this attribute is required (when there is only one layer, it automatically applies to the first layer. One of the other issues with the current MBStyle codebase is it doesn’t have all that good error messages yet (some parts are pretty good, but then you get an error like the one you ran into, which isn’t helpful at all).
Try something like this for your style:
“version”: 8,
“layers”: [
“source-layer”: “countries”,
“type”: “fill”,
“paint”: {
“type”: “fill”,
“paint”: {
(Replace “countries” with the name of the layer you are styling)
For more information about styling with MBStyle, take a look at this tutorial. It explains a bit more about how to use MBStyle with multiple layers, and how to make best use of source-layer.
Torben
On Fri, Jun 7, 2019 at 4:08 PM Torben Barsballe <tbarsballe@anonymised.com> wrote:
Hi Florent,
“version”: 8,
“layers”: [
“type”: “fill”,
“paint”: {
“type”: “fill”,
“paint”: {
Torben
On Thu, Jun 6, 2019 at 2:24 AM Florent Gravin <florent.gravin@anonymised.com> wrote:
Hi Jody,
“version”: 8,
“layers”: [
“type”: “fill”,
“paint”: {
On Wed, Jun 5, 2019 at 7:02 AM Jody Garnett <jody.garnett@anonymised.com> wrote:
Jody Garnett
On Tue, 4 Jun 2019 at 02:09, Florent Gravin <florent.gravin@anonymised.com> wrote:
Hi guys,
“version”: 8,
“layers”: [
“type”: “fill”,
“paint”: {
“type”: “fill”,
“paint”: {
Thanks for hints
camptocamp
Florent Gravin
+33 4 58 48 20 36
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
If you want to request a feature or an improvement, also see this: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
camptocamp
Florent Gravin
+33 4 58 48 20 36
Thanks Torben, it’s exactly what I needed !
camptocamp
Florent Gravin
+33 4 58 48 20 36
