On Sun, Sep 6, 2015 at 1:28 AM, Jim Proctor <jproctor@anonymised.com> wrote:
Thank you! So, I went to Demos > WPS Request Builder, and selected the
process gs:MBTiles. Required inputs from documentation below
<http://docs.geoserver.org/stable/en/user/community/mbtiles/output.html> are
layername and format; it is possible I entered them incorrectly, but upon
execution I received the following:
gs:MBTilesMBTilesMBTiles ProcessProcess failed during execution
java.lang.NoSuchMethodError:
org.geoserver.wps.resource.WPSResourceManager.getOutputResource(Ljava/lang/String;Ljava/lang/String;)Lorg/geoserver/platform/resource/Resource;
To confirm: (a) should layername include store:layer as in typical WMS
call?; and (b) should format equal mbtiles, or application/x-sqlite3,as in
mbtiles Layer Preview call? (The process generates the same error above no
matter how I complete these fields.)
With that error like that, you likely mixed in the plugin for a different
GeoServer version, e.g.,
a 2.7.x plugin with a 2.5.x release, or something like that.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
