[Geoserver-users] MBTiles Plugin on geoserver 2.6.2
Hello!
I am running geoserver 2.6.2 stable on Ubuntu 14.04, tomcat 7. Everything works fine but when I copy the mbtiles.zip into the WEB-INF/lib.
I read that the version of the mbtiles plugin must match the version of the Geoserver. I only found the plugin into this folder [1] and when I copy into the geoserver/WEB-INF/lib folder, the app stopped and I cannot start again. I guess it is not the right version then.
Anybody installed the mbtile plugin on 2.6.2 successfully?
Thanks in advance.
Simone
[1] http://ares.opengeo.org/geoserver/2.6.x/community-latest/
Simone Gadenz
BEECOME S.R.L.
Via Sansedoni 7, 53100 SIENA - ITALY
Phone/Fax: +39 0577 588408
www.beecome.it
simone@anonymised.com
Informativa Privacy - Ai sensi del D. Lgs n. 196/2003 (Codice Privacy) si precisa che le informazioni contenute in questo messaggio sono riservate e ad uso esclusivo del destinatario. Qualora il messaggio in parola Le fosse pervenuto per errore, La preghiamo di eliminarlo senza copiarlo e di non inoltrarlo a terzi, dandocene gentilmente comunicazione. Grazie.
Privacy Information - This message, for the D. Lgs n. 196/2003 (Privacy Code), may contain confidential and/or privileged information. If you are not the addressee or authorized to receive this for the addressee, you must not use, copy, disclose or take any action based on this message or any information herein. If you have received this message in error, please advise the sender immediately by reply e-mail and delete this message. Thank you for your cooperation.
