On Mon, Mar 2, 2015 at 10:46 PM, simone gadenz <simone@anonymised.com> wrote:
Thanks Andrea.
I will have a look into code, I asked because it looked strange to me there was not a repository of the community modules related to the stable versions.
S
Simone Gadenz BEECOME S.R.L. Via Sansedoni 7, 53100 SIENA - ITALY Phone/Fax: +39 0577 588408 www.beecome.it simone@anonymised.com… |
------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- Informativa Privacy - Ai sensi del D. Lgs n. 196/2003 (Codice Privacy) si precisa che le informazioni contenute in questo messaggio sono riservate e ad uso esclusivo del destinatario. Qualora il messaggio in parola Le fosse pervenuto per errore, La preghiamo di eliminarlo senza copiarlo e di non inoltrarlo a terzi, dandocene gentilmente comunicazione. Grazie.
Privacy Information - This message, for the D. Lgs n. 196/2003 (Privacy Code), may contain confidential and/or privileged information. If you are not the addressee or authorized to receive this for the addressee, you must not use, copy, disclose or take any action based on this message or any information herein. If you have received this message in error, please advise the sender immediately by reply e-mail and delete this message. Thank you for your cooperation.
On Mar 2, 2015, at 10:38 PM, Andrea Aime wrote:
Hi Simone,
just confirming the message you sent did reach the mailing list.
The MBTiles plugin is a “community module”, as such, unsupported (supported modules are the base package, and the extensions, that is, what you can find in a release download page).
That said, you might get an answer, but there are no guarantees… if you can develop, you’re welcome to dive into the module sources and see what might or might not be working.
Dive into the World of Parallel Programming The Go Parallel Website, sponsored
by Intel and developed in partnership with Slashdot Media, is your hub for all
things parallel software development, from weekly thought leadership blogs to
news, videos, case studies, tutorials and more. Take a look and join the
conversation now. http://goparallel.sourceforge.net/
Geoserver-users mailing list
Simone Giannecchini
GeoServer Professional Services from the experts! Visit http://goo.gl/NWWaa2 for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via Poggio alle Viti 1187
mob: +39 333 8128928
On Mon, Mar 2, 2015 at 10:16 PM, simone gadenz <simone@…6907…> wrote:
Hello!
I am running geoserver 2.6.2 stable on Ubuntu 14.04, tomcat 7. Everything works fine but when I copy the mbtiles.zip into the WEB-INF/lib.
I read that the version of the mbtiles plugin must match the version of the Geoserver. I only found the plugin into this folder [1] and when I copy into the geoserver/WEB-INF/lib folder, the app stopped and I cannot start again. I guess it is not the right version then.
Anybody installed the mbtile plugin on 2.6.2 successfully?
Thanks in advance.
Simone
[1] http://ares.opengeo.org/geoserver/2.6.x/community-latest/
Ing. Andrea Aime
@geowolf
Technical Lead
mob: +39 339 8844549
