[Geoserver-users] Memory Leak after deploying geoserver.war
Dear Geoserver Users,
I have deployed a new geoserver.war in a new tomcat instance. Currently I cannot work with it, because my http/ajp mapping isn’t configured correctly.
Besides that, I get the following output in the catalina.out log. (see the log below)
There seems to be a problem with a memory leak and the Threadpool.
Can you give me a hint what is going wrong and if that is a problem.
Thank you in advance.
Christoph
INFORMATION: Cleaned up javabean caches
Apr 10, 2015 11:16:46 AM org.apache.catalina.loader.WebappClassLoader clearReferencesThreads
SCHWERWIEGEND: The web application [/geoserver] appears to have started a thread named [pool-5-thread-1] but has failed to stop it. This is very likely to create a memory leak.
Apr 10, 2015 11:16:46 AM org.apache.catalina.loader.WebappClassLoader checkThreadLocalMapForLeaks
SCHWERWIEGEND: The web application [/geoserver] created a ThreadLocal with key of type [org.eclipse.emf.ecore.xml.type.util.XMLTypeUtil.CharArrayThreadLocal] (value [org.eclipse.emf.ecore.xml.type.util.XMLTypeUtil$CharArrayThreadLocal@anonymised.com]) and a value of type [char] (value [[C@anonymised.com]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
SCHWERWIEGEND: The web application [/geoserver] created a ThreadLocal with key of type [java.lang.ThreadLocal] (value [java.lang.ThreadLocal@anonymised.com]) and a value of type [org.springframework.security.core.context.SecurityContextImpl] (value [org.springframework.security.core.context.SecurityContextImpl@anonymised.com: Null authentication]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
SCHWERWIEGEND: The web application [/geoserver] created a ThreadLocal with key of type [org.eclipse.emf.ecore.impl.EClassImpl$1] (value [org.eclipse.emf.ecore.impl.EClassImpl$1@anonymised.com]) and a value of type [java.util.HashSet] (value []) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
Apr 10, 2015 11:16:46 AM org.apache.catalina.startup.HostConfig deployWAR
INFORMATION: Deployment of web application archive /var/lib/tomcat/geoserver_master/webapps/geoserver.war has finished in 35,834 ms
Apr 10, 2015 11:16:46 AM org.apache.coyote.AbstractProtocol start
INFORMATION: Starting ProtocolHandler [“http-bio-8080”]
INFORMATION: Starting ProtocolHandler [“ajp-bio-9018”]
Apr 10, 2015 11:16:46 AM org.apache.catalina.startup.Catalina start
INFORMATION: Server startup in 35948 ms
On Fri, Apr 10, 2015 at 1:28 PM, Christoph Kleih <christoph.kleih@anonymised.com>
cannot work with it, because my http/ajp mapping isn't configured correctly.
log below)
It's a known issue without an easy solution, GeoServer is a complex, large
web applications
that uses a set of technologies which weren't exactly meant to be used in a
webapp context (emf, jai).
I've tried to fix those errors spending a few days some years ago, without
any luck, and in time,
more of them piled up (since nobody managed to solve them all, and it does
not make a difference
if you get 1 or 100 of them, you still end up with a permgen leak).
The usual approach is to deploy GeoServer in its own private Tomcat, and
shut it down when
you need to redeploy. Not as bad as it sounds, considering that GeoServer
will force you to
increase the permgen settings anyways (at least 128m) and under load it
ends up eating a
good portion of your heap (each WMS request allocates a few megabytes of
heap for the
drawing surface, large ones can reach the tens of MB, by the time you have
some concurrent load
using a couple GB of memory is not uncommon)
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
