Gabriel & Justin,
I have used Yourkit to collect some more information. I made two snapshots of the heap while running my tests. In Yourkit I used the Inspections feature and ran the tests under 'Possible leaks'. The 'Lost SWT Controls' test returned nothing. The 'Objects Retained by Inner Class Back References' test did return a few classes. Between the first and the second snapshot the classes that the test returned and the number of instances were the same for all but one. In my first snapshot the class org.geotools.xml.impl.SchemaIndexImpl appeared 470 times taking up 15% of the heaps retained size. In my second snapshot this class appeared 940 times taking up 25% of the heaps retained size. All of the instances of this class were made up of an array of org.eclipse.xsd.XSDSchemaImpl objects and three HashMap objects.
Under the Memory feature of Yourkit I found that the HashMap class was taking up the majority of the memory in both snapshots. I then used the 'Merged paths' feature of Yourkit to determine what objects were retaining the memory held by HashMap. I found that the one class that held more of this memory than any other was again org.geotools.xml.impl.SchemaIndexImpl. The memory for this class was being held by org.geotools.xml.impl.SchemaIndex$SchemaAdapter whose memory was held by org.eclipse.emf.notify.Adapter whose memory was held by org.eclipse.emf.common.notify.impl.BasicNotifierImpl$EAdapterList whose memory was held by org.eclipse.xsd.impl.XSDSchemaImpl whose memory was held by instances of multiple other classes.
From this information I now believe that while the HashMap is taking up the majority of memory it is most likely because of the class org.geotools.xmlimpl.SchemaIndexImpl or one of the classes that retain a hold on that class that I listed above.
The WFS insert transaction statements and getFeature requests that I send the server use the schemas for wfs, ogc, gml, and the regular xml. Also I created another schema to represent my own data. Is it possible that this memory leak is occurring because of my schema document? Currently my instance of GeoServer does not have access to my schema document.
Brett
-----Original Message-----
From: Gabriel Roldán [mailto:groldan@anonymised.com]
Sent: Tuesday, September 09, 2008 4:05 PM
To: Levasseur, Brett; Justin Deoliveira
Cc: David R Robison; geoserver-users@lists.sourceforge.net
Subject: Re: [Geoserver-users] Memory Leak
On Tuesday 09 September 2008 04:37:03 pm Levasseur, Brett wrote:
Gabriel,
I will check out using Yourkit like you suggested. Until then I used jhat
to go through a dump of the heap from one of my trials. I checked the first
150 instances of the class java.util.HashMap$Entry and found that among
them 147 had the same setup with a key being an instance of the class
javax.xml.namespace.QName and a value being an instance of the class
org.eclipse.xsd.impl.XSDElementDecleration. These instances of the HashMap
class are referenced by instances of the class
I will know more once I have had the chance to collect more data, however
if the appearance of the classes I have mentioned above proves to be the
pattern would this fall under the category of the xml parser?
yes, or rather under the category of the whole xml subsystem, so called gt-xsd
extensions. These are xml schema aware parsers that use java binding classes
and the eclipse emf framework. I wonder if we are certain that the leak is
due to stale HashMap instances, and I would suspect of the xsd caches, but to
have more than guessing you may want to contact Justin, cc'ed here, whose the
expert on this.
keep us posted.
Gabriel
Brett Levasseur
Sent: Tuesday, September 09, 2008 10:47 AM
To: David R Robison
Cc: geoserver-users@lists.sourceforge.net; Levasseur, Brett
hi david,
no i can't know without a profiler, that's what i was saying before.
gabriel
On Tuesday 09 September 2008 09:37:41 am David R Robison wrote:
> Can you explain a bit more about what with the XML Parser causes it to
> leak memory? I am also seeing some memory leaks and it appears that it
> is related to the XML Parser. Any hints on how to track this down, or
> where to look for typical problems in the code would be greatly
> appreciated. TNX David
> Gabriel Roldán wrote:
> > Hi Brett,
> > there's a usual suspect, xml paser. But I may be wrong and the leak
> > laying out in another place. That inspection of yours does not tell who
> > creates the hashmaps, does it?
> > I'm tempted to hit geoserver like that but running under a profiler for
> > a while but that'd be constrained by higher priorities. Wonder if you
> > could manage to make the same longevity testing with Yourkit java
> > profiler (there's a trial version and we have geotools specific
> > licences) so we can analyze a profiler's snapshot?
> > best regards,
> > Gabriel
> > On Friday 05 September 2008 05:06:40 pm Levasseur, Brett wrote:
> >> Hello,
> >> I am trying to run a Web Feature Service with GeoServer but I am
> >> experiencing a memory leak. I have a Java program that sends new
> >> features to GeoServer in an http post that then get added to a PostGIS
> >> database. The total amount of data that gets sent to the server is
> >> very small, usually less than a couple of dozen of features per http
> >> post. Also each feature is only made up of five fields (a position, a
> >> time stamp, and a few numbers) so the amount of data that I am
> >> expecting GeoServer to handle is very small. After about a day of
> >> running the program on tomcat I found that the server was using up
> >> much more memory than it had the day before. I looked at the heap and
> >> found that the class java.util.HashMap had more instances then any
> >> other class and was taking up more memory then any other class. Does
> >> anyone have any idea what could be causing this memory leak? I am
> >> running GeoServer version 1.6.4 and tomcat version 6.0.18.
> >> Brett
> >-- This SF.Net email is sponsored by the Moblin Your Move Developer's
> > challenge Build the coolest Linux based applications with Moblin SDK &
> > win great prizes Grand prize is a trip for two to an Open Source event
> > anywhere in the world
> > http://moblin-contest.org/redirect.php?banner_id=100&url=/
> > _______________________________________________
> > Geoserver-users mailing list
> > Geoserver-users@lists.sourceforge.net
> > https://lists.sourceforge.net/lists/listinfo/geoserver-users
