[Geoserver-users] Mercator projection problem
Huh. This string is from Esri ArcView prj file
PROJCS[“Custom”,GEOGCS[“GCS_Sphere”,DATUM[“D_Sphere”,SPHEROID[“Sphere”,6371000,0]],PRIMEM[“Greenwich”,0],UNIT[“Degree”,0.017453292519943295]],PROJECTION[“Mercator”],PARAMETER[“False_Easting”,0],PARAMETER[“False_Northing”,0],PARAMETER[“Central_Meridian”,0],PARAMETER[“Standard_Parallel_1”,0],UNIT[“Meter”,1]]
If i use this mercator projection in arcview my data is on right position. But if i create custom projection in geoserver in epsg.properties file like (copy string from prj file)
54004=PROJCS[“Custom”,GEOGCS[“GCS_Sphere”,DATUM[“D_Sphere”,SPHEROID[“Sphere”,6371000,0]],PRIMEM[“Greenwich”,0],UNIT[“Degree”,0.017453292519943295]],PROJECTION[“Mercator”],PARAMETER[“False_Easting”,0],PARAMETER[“False_Northing”,0],PARAMETER[“Central_Meridian”,0],PARAMETER[“Standard_Parallel_1”,0],UNIT[“Meter”,1]]
result differs from arcview. Any clue.
Thx Grega
No virus found in this outgoing message.
Checked by AVG Free Edition.
Version: 7.5.488 / Virus Database: 269.13.32/1032 - Release Date: 26.9.2007 20:20
