[Geoserver-users] Merge polygons
Hey!
I have two polygons (from a shape file) which share an edge, i can render
each one perfectly (left image side). Now i'd like to render this 2 polygons
as one polygon (right image side). Would this be possible using some special
SLD filter? Or is this not possible at all.
http://www.nabble.com/file/p20619948/polys.png
View this message in context: http://www.nabble.com/Merge-polygons-tp20619948p20619948.html
GeoUser ha scritto:
Hey!
Not possible at all, SLD does not alter the geometric nature of the
data. If you need that, you'll have to use some other tool to merge the
polygons (postgis has merge functions for example, so you could eventually create a view that does the merge on the fly).
Andrea Aime
OpenGeo - http://opengeo.org
I see, i was expecting something like that :wink:
This seems like something that could help with the problem. What's the
status of this?
http://geoserver.org/display/GEOS/selectDerivedFeatureType docs
View this message in context: http://www.nabble.com/Merge-polygons-tp20619948p20621197.html
status of this?
As you can see the page is 3 years old. It's the first time I see
it actually, so I can assure you that thing is dead.
We're considering adding the ability to specify a query to
build a new feature type for JDBC databases, but it's not trivial
and we have no one sponsoring/working on it so it won't be done anytime
soon.
The good news is that you can buid a view in your database and then
you can treat it like any other feature type, so you don't actually
need the above.
Andrea Aime
Yes, i saw that it is 3 years old, that's why i thought that something has
been done in this area. I guess i'll check out the views.
Thanks for the info Andrea!
status of this?
soon.
need the above.
Andrea Aime
This SF.Net email is sponsored by the Moblin Your Move Developer's
challenge
Build the coolest Linux based applications with Moblin SDK & win great
prizes
Grand prize is a trip for two to an Open Source event anywhere in the
world
http://moblin-contest.org/redirect.php?banner_id=100&url=/
Geoserver-users mailing list
View this message in context: http://www.nabble.com/Merge-polygons-tp20619948p20621404.html
