[Geoserver-users] METADATA EXTENSION CONNECTING GEOSERVER AND GEONETWORK
I’ve seen that there is a plugin for metadata that let’s import and create a connection between geoserver and geonetwork. I’ve seen it here: https://docs.geoserver.org/latest/en/user/community/metadata/configuration.html. But when I go to the downloads page it is not there.
Anyone can help me find it? Or do you have any idea how we could do it?
Thanks!
https://build.geoserver.org/geoserver/master/community-latest/ is the usual location for community modules.
It won’t be in the normal “numbered” release, because we don’t release community modules. They are for further development, and don’t get the normal level of support or testing.
Brad
Sent: Saturday, 13 June 2020 4:46 PM
To: geoserver-users@anonymised.comourceforge.net
Subject: [Geoserver-users] METADATA EXTENSION CONNECTING GEOSERVER AND GEONETWORK
Thanks!
Thank you very much Brad!
Brad
Thanks!
Hi Brad,
I’ve been trying to install the extension but when I add de .jar files in the geoserver\WEB-INF\lib folder geoserver crashes and I cannot start it.
I think It should be easy but it is not working. I downloaded both the 2.17 version and the 2.18 (in case it works for me) with no luck.
Any idea?
Thanks again for your help!
El lun., 15 jun. 2020 a las 8:46, XAVIER RAYO SARRIAS (<xrayo@anonymised.com>) escribió:
Brad
Thanks!
You’ll need to make sure the plugin version matches the GeoServer version. If you can’t find an exact match you may need to compile the plugin yourself using the right version from github
Ian
Ian Turton
