[Geoserver-users] Metadata links
Hello,
I found something strange about the metadata links in GeoServer. Mine is 2.6.0.
In fact when I add a metadata link to one of my layer. For example : http://file_host/filename.xml.
Then in the GetCapabilities response, I found that the server associated to the link has been changed and the geoserver host is used instead.
Let say that my Geoserver host is http://192.111.11.11/geoserver then the link to my metadata will be changed to http://192.111.11.11/geoserver/filename\.xml
Mickael
I keep my GeoServer data folder separate and pointed the new 2.6.1 upgrade at it
The cache was generated before I upgraded
My Disk quota reports :-
Using -5,445,513,216.0 B of a maximum 25.0 GB
My tile cache layers report :-
Geostore:OS Meridian 5.07 GB
Geostore:OS Strategi 5.07 GB
Geostore:OSMM Web 2.71 GB
Geostore:OS VML - Web 1.31 GB
Geostore:OS VMD - Web 9.41 MB
Approx 14gb in total
When I do a folder check on the server the smallest cache layer Geostore:OS VMD – Web is actually reported as :-
Size = 207mb
Size on disk = 5.08 gb
Is there any way to reconcile the size of the cache being reported differently (and incorrectly) in different parts of geoserver ?
I am using in process database H2
Mark Ismail
Principal IT Officer
Hi Mark,
Yep, that’s an issue I kept getting, though hard to reliably reproduce which is probably why it’s not fixed yet.
If memory serves, to resolve the issue you need to disable disk quota and re-enable it. You may need to delete the database too while it’s turned off.
Jonathan
Sent: Wednesday, November 26, 2014 1:18 PM
To: geoserver-users
Subject: [Geoserver-users] Geowebcache issues after 2.6.1 upgrade
Size = 207mb
Mark Ismail
This e-mail and any attachments are confidential. It may contain privileged information and is intended for the named recipient(s) only. It must not be distributed without consent. If you are not one of the intended recipients, please notify the sender immediately and do not disclose, distribute, or retain this email or any part of it and do not take any action based on it.
Unless expressly stated, opinions in this email are those of the individual sender, and not of Knowsley MBC. Legally binding obligations can only be created for, or be entered into on behalf of, Knowsley MBC by duly authorised officers or representatives.
Knowsley MBC excludes any liability whatsoever for any offence caused, any direct or consequential loss arising from the use, or reliance on, this e-mail or its contents. We believe but do not warrant that this e-mail and any attachments are virus free. You must therefore take full responsibility for virus checking and no responsibility is accepted for loss or damage arising from viruses or changes made to this message after it was sent. Knowsley MBC reserves the right to monitor and/or record all e-mail communications through its network in accordance with relevant legislation.
This message has been scanned for viruses by MailControl, a service from BlackSpider Technology
Click here to report this email as spam.
