[Geoserver-users] Migrate Store Configuration
I have GeoServer running on Linux server with store and layers configured. I
need to create a new store and migrate the same configuration (Layers,
Styles, Caching settings... etc) of the original store into the new one. I
created a folder under
/var/lib/tomcat7/webapps/geoserver/data/workspaces/myWS/ with the new
store's name. Then copied original store files into it. I thought this is
enough but when I connected the new store nothing appears, no layers no
styles nothing. What I'm missing here?
View this message in context: http://osgeo-org.1560.x6.nabble.com/Migrate-Store-Configuration-tp5192492.html
I
Hum... just making a guess, but the xml files are linked with each other via
identifiers, have you updated your datastore.xml to point to the id of the
new containing workspace?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
What happened is GeoServer stopped and never run until I remove the new store
settings! It seems that what I want to do is not possible.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Migrate-Store-Configuration-tp5192492p5192949.html
