I’ve recently installed a 2.2.3 on our webserver and need to migrate all the stores/workspaces/layers/styles from the older geoserver (2.1.0). I tried to copy/paste data_dir from the older to the new one, but that doesn’t seem to work. What are the steps that have to be taken in order to make it work? I have a lot of data and I can’t import them manually. Thank you.
Master HTML5, CSS3, ASP.NET, MVC, AJAX, Knockout.js, Web API and
much more. Get web development skills now with LearnDevNow -
350+ hours of step-by-step video tutorials by Microsoft MVPs and experts.
SALE $99.99 this month only – learn more at:
[http://p.sf.net/sfu/learnmore_122812](http://p.sf.net/sfu/learnmore
_122812)
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
I’ve followed the instructions on that page (though there are not really a lot of them) with no success. I’ve left security folder unchanged and just uploaded the data, with no success.
SALE $99.99 this month only – learn more at: http://p.sf.net/sfu/learnmore_122812
Instead of copying the entire data directory try copying only the following
directories from 2.1:
coverages (If you're storing the data in the data dir)
data (If you're storing the data in the data dir)
gwc
layergroups (if you have any)
styles
workspaces
This usually works...
Another approach is using the REST API to configure all the layers.
You cannot left the security folder unchanged, this will not work. Did you try
to start 2.2.3 using the data directory from 2.1.0 (make a backup first!!!).
There is a lot of migration code in 2.2.x
Christian
Zitat von Michal Zimmermann <zimmicz@anonymised.com>:
I've followed the instructions on that page (though there are not really a
lot of them) with no success. I've left security folder unchanged and just
On Fri, Jan 18, 2013 at 2:10 PM, Jonathan Moules <
jonathanmoules@anonymised.com> wrote:
On 18 January 2013 12:49, Michal Zimmermann <zimmicz@anonymised.com> wrote:
I've recently installed a 2.2.3 on our webserver and need to migrate all
doesn't seem to work. What are the steps that have to be taken in order to
make it work? I have a lot of data and I can't import them manually. Thank
you.
SALE $99.99 this month only -- learn more at: http://p.sf.net/sfu/learnmore_122812
________________________ _______________________
Geoserver-users mailing list
Geoserver-users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/geoserver-users
I have the whole data_dir directory from 2.1.x geoserver backed up and the clean installation of 2.2.3. What should I do? I would like to try with just a piece of my data if it works, so I decided to upload one directory of shapefiles from data_dir/data.
you.
Hmm… we don’t have specific procedures to try “just a bit”, the normal approach is to
give the entire data dir to the newer GeoServer.
Normally some parts of the configuration get updated, but I cannot remember of cases
in which the data itself was touched, nor I remember of code that would do such an
operation.
operation.
