[Geoserver-users] Migrating from 1.6.3 to 1.7.2
Hello
I have just started the process to migrate from GeoServer
1.6.3 to 1.7.2. Using the configuration from 1.6.3 I initially
got a null pointer exception which I tracked down to <maxFeatures>
in services.xml (not present in my 1.6.3 config, apparently
mandatory in 1.7.2).
When I located this problem, I noticed that GeoServer was using
a class LegacyConfigurationImporter. That sounds to me as if
1.7.2 expects a different configuration format. However, I cannot
find any structural differences between my 1.6.3 config and
the default config in the 1.7.2 geoserver.war.
So, is there a new config format, and if so, where can I find
documentation of this?
Nils Weinander | Systems Designer
Phone +46 (0)8 410 064 56
Mobile +46 (0)70 978 28 37
Curalia AB | www.curalia.se
Hudiksvallsgatan 4, 113 30 Stockholm, Sweden
Nils Weinander wrote:
Hello
No new format today, we'll have one in GeoServer 2.0, and
that class represents a sort of a step towards moving to
a new format and a new set of catalog/config classes.
Please open a jira issue (jira.codehaus.org) for the issue
you've found, and every other you might find,
so that we can track it and eventually fix it.
Hello
Ah! thanks.
Done:
http://jira.codehaus.org/browse/GEOS-2640
I have labelled it as a bug, but written in the description
that I'm not sure if it is a bug or just something that
needs to be documented.
