[Geoserver-users] Migrating from Mapserver to GeoServer
I'm thinking of migrating my MapServer MS4W service over to GeoServer. The MS4W comes with Apache and PHP that are out of date, and I don't seem to be able to update them without breaking the mapserver. Are there any guides on migrating a mapserver mapfile over to be served up by GeoServer?
James
Hi James,
I don’t think I’ve ever seen mention of a way of automating the migration; might be worth asking on the MapServer list.
I suspect it’s possible to create a tool to do it (read the mapfile and turn it into SLD’s). You’re probably going to have to do it manually though.
Jonathan
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
On 25 February 2014 20:10, EVANS, JAMES R GS-13 USAF ACC 84 RADES/SCZE <james.evans.4@anonymised.com> wrote:
I’m thinking of migrating my MapServer MS4W service over to GeoServer. The MS4W comes with Apache and PHP that are out of date, and I don’t seem to be able to update them without breaking the mapserver. Are there any guides on migrating a mapserver mapfile over to be served up by GeoServer?
James
Flow-based real-time traffic analytics software. Cisco certified tool.
Monitor traffic, SLAs, QoS, Medianet, WAAS etc. with NetFlow Analyzer
Customize your own dashboards, set traffic alerts and generate reports.
Network behavioral analysis & security monitoring. All-in-one tool.
http://pubads.g.doubleclick.net/gampad/clk?id=126839071&iu=/4140/ostg.clktrk
Geoserver-users mailing list
Dear James,
a client of ours is developing a groovy script to do that.
I can't ensure it is error-proof as the process is complex, but I can
see if he is interested in contributing it.
What do you think?
Simone Giannecchini
Our support, Your Success! Visit http://opensdi.geo-solutions.it for
more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via Poggio alle Viti 1187
mob: +39 333 8128928
On Mon, Mar 3, 2014 at 12:41 PM, Jonathan Moules
<jonathanmoules@anonymised.com> wrote:
Hi James,
I don't think I've ever seen mention of a way of automating the migration;
I suspect it's possible to create a tool to do it (read the mapfile and turn
it into SLD's). You're probably going to have to do it manually though.
Jonathan
James
Subversion Kills Productivity. Get off Subversion & Make the Move to
Perforce.
With Perforce, you get hassle-free workflows. Merge that actually works.
Faster operations. Version large binaries. Built-in WAN optimization and
the
freedom to use Git, Perforce or both. Make the move to Perforce.
http://pubads.g.doubleclick.net/gampad/clk?id=122218951&iu=/4140/ostg.clktrk
Hi Simone,
I would be happy to give it a go. It might be a good test. My mapfile has
a mix of raster (LIDAR, GEOTiffs, JP200s, JPGs, IGE, CADRG) and vector data.
Let me know what I need to do to try that out.
James
-----Original Message-----
From: simboss1@anonymised.com [mailto:simboss1@anonymised.com] On Behalf Of Simone
Giannecchini
Sent: Monday, March 03, 2014 9:01 AM
To: Jonathan Moules
Cc: EVANS, JAMES R GS-13 USAF ACC 84 RADES/SCZE;
geoserver-users@lists.sourceforge.net
Subject: Re: [Geoserver-users] Migrating from Mapserver to GeoServer
Dear James,
I can't ensure it is error-proof as the process is complex, but I can see if
What do you think?
Simone Giannecchini
Our support, Your Success! Visit http://opensdi.geo-solutions.it for more
information.
@simogeo
Founder/Director
Hi James,
and turn it into SLD's). You're probably going to have to do it manually
though.
Jonathan
GeoServer?
James
--------- Flow-based real-time traffic analytics software. Cisco
certified tool.
.clktrk _______________________________________________
-------- Subversion Kills Productivity. Get off Subversion & Make the
Move to Perforce.
and the freedom to use Git, Perforce or both. Make the move to
Perforce.
Hi Simone,
What do you think?
I know that we once in a while have cases, where we migrate between
the two (MapServer/GeoServer), due to the different areas where each
has it strengths - or even run mixed environments.
I would therefore also be interested in the possibility of seeing said script, .
Greg
Hans Gregers Petersen
Partner, Senior Consultant
www.septima.dk
