I have published some WMS services using geoserver 2.4. I have created an
sld for layers. I have added MinScaleDenominator and MaxScaleDenominator in
rules tag and trying to access the wms layer in Google Earth, the wms layer
doesnot show any kind of data. If I remove the denominators tags from sld
rule, data is visible. Please suggest where exactly the problem is.
Prasanth.
View this message in context: http://osgeo-org.1560.x6.nabble.com/MinScaleDenominator-MaxScaleDenominator-are-not-reflecting-in-Google-Earth-tp5140426.html
Hi Prasanth,
I’m not seeing this myself. Try this KML file - http://maps.warwickshire.gov.uk/misc/All_WMS_External_Layers.kml - if you zoom in on the town of Warwick (or anywhere in Warwickshire), and enable StreetLights, you’ll see they only come in when zoomed in; which is correct, they have a denominator set as:
se:MaxScaleDenominator30100</se:MaxScaleDenominator>
These are using the KML network link, and the data’s default projection is 27700 (compared to google Earths 4326). Can you confirm that your layers work fine in the OpenLayers preview?
Jonathan
This transmission is intended for the named addressee(s) only and may contain confidential, sensitive or personal information and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
On 15 May 2014 10:41, mallelaprasanth <mallelaprasanth@anonymised.com> wrote:
Prasanth.
“Accelerate Dev Cycles with Automated Cross-Browser Testing - For FREE
Instantly run your Selenium tests across 300+ browser/OS combos.
Get unparalleled scalability from the best Selenium testing platform available
Simple to use. Nothing to install. Get started now for free.”
http://p.sf.net/sfu/SauceLabs
Geoserver-users mailing list
