[Geoserver-users] Misconfigured datastore?
Hi Geoserver community,
I am using opengeo suite 2.5 on a windows 2008 server and after doing a system reboot, opengeo suite will not restart.
The log indicate the following geoserver error:
0 [main] WARN org.geoserver.logging - Could not find configuration file for logging
2154 [main] ERROR org.vfny.geoserver.global -
  • GEOSERVER_DATA_DIR: C:\Program Files (x86)\OpenGeo\OpenGeo Suite\webapps\geoserver\data
2180 [main] INFO org.geoserver.config.GeoServerPropertyConfigurer - Loading properties file from URL [file:/C:/Program%20Files%20(x86)/OpenGeo/OpenGeo%20Suite/webapps/geoserver/data/monitoring/hibernate.properties]
After extensive googling, it seems this is related to a Misconfigured datastore that prevents geoserver startup. Is there any way to fix this problem without reinstalling opengeo suite or geoserver?
Stacy
