[Geoserver-users] Missing geowebcache.xsd
Hi again,
Does anyone know why GeoServer 2.12.0 references version 1.12.0 of the GWC but it doesn’t appear to exist?
The URL given is http://geowebcache.org/schema/1.12.0/geowebcache.xsd but the most recent version appears to be http://geowebcache.org/schema/1.11.0/geowebcache.xsd
Paul
https://sourceforge.net/projects/geowebcache/files/geowebcache/1.12.0/ seems to be there. So there may need to be an update needed to the GWC web site. You may want to ask over on the gwc lists
Ian
On 7 November 2017 at 15:46, Paul Wittle via Geoserver-users <geoserver-users@lists.sourceforge.net> wrote:
Hi again,
Paul
“This e-mail is intended for the named addressee(s) only and may contain information about individuals or other sensitive information and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this email in error, kindly disregard the content of the message and notify the sender immediately. Please be aware that all email may be subject to recording and/or monitoring in accordance with relevant legislation.”
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
Geoserver-users@anonymised.com.382…sourceforge.net
Ian Turton
