[Geoserver-users] modify_epsg:properties_for brandenburg
Hello list,
can you pls help me to modify
epsg.properties< for State of Brandenburg (Germany) similar to this:
(from:
http://www.nabble.com/Projection-problem-Mapserver-Geoserver-Geotools-td8939186.html)
28992=PROJCS["Amersfoort / RD
New",GEOGCS["Amersfoort",DATUM["Amersfoort",SPHEROID["Bessel
1841",6377397.155,299.1528128,AUTHORITY["EPSG","7004"]],AUTHORITY["EPSG","6289"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.01745329251994328,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4289"]],PROJECTION["Oblique_Stereographic"],PARAMETER["latitude_of_origin",52.15616055555555],PARAMETER["central_meridian",5.38763888888889],PARAMETER["scale_factor",0.9999079],PARAMETER["false_easting",155000],PARAMETER["false_northing",463000],UNIT["metre",1,AUTHORITY["EPSG","9001"]],AUTHORITY["EPSG","28992"]]
but for EPSG 25833 at Brandenburg with Data x: 3340000 y: 5600000 (both with
7 numbers)???
According to EPSG 25833 I need x only with 6 numbers like x: 340000 (y can
stay with 7 numbers).
So I want something like false easting=-3000000 at the epsg:properties.
By the help of others I could do this with UMN, so I hope this is possible
to GeoServer as well.
Thanks for any help,
Robert
View this message in context: http://www.nabble.com/modify_epsg%3Aproperties_for-brandenburg-tp17406679p17406679.html
