[Geoserver-users] modify the shapefile's contour
http://www.nabble.com/file/p13489658/province.shp province.shp
Can I modify the shapefile's contour?
I must join the provinces.
How can I modify the Contour's color?
Thanks
Diana
View this message in context: http://www.nabble.com/modify-the-shapefile's-contour-tf4718770.html#a13489658
You can modify the contour color by using the Stroke element
in SLD (have a look at the sample SLD files and read the SLD
specification here http://portal.opengeospatial.org/files/?artifact_id=1188).
If you want to make the borders of provinces in the same
region disappear that's another story, it's processing.
You may be able to do that using a desktop GIS (I think
gvSig can do that but I'm not sure) or by
importing data into PostGIS and perform the merges using the
spatial analysis operations provided.
Hope this helps
Andrea,
my needs are to "merge" the contour of a set of privince into
"super-province" that is the "union" of more of them. For example merge
lucca&massa into a "area versilia".
Do u think that sw like "gvSig" can be useful to do this?
Do u know other software that can help me?
Have u some example to show?
Thanks
Diana
specification here
Hope this helps
Geoserver-users mailing list
View this message in context: http://www.nabble.com/modify-the-shapefile's-contour-tf4718770.html#a13512332
diana2 ha scritto:
Andrea,
I'm not really sure, I only used gvsig as a viewer, yet
in this presentation: http://www.gvsig.gva.es/fileadmin/conselleria/images/Documentacion/ponencias/Presentacion_gisplanet_2005_parte3.pdf
they do mention merge as one of gvSig capabilities.
Udig should have some experimental modules to do merge
too, but they are not super easy to install and quite
experimental
Unfortunately not.
"Merge two polygons", "Union" and "Union by attribute value" functions in OpenJUMP
(http://openjump.org) might be right for you. It has also a pretty well working WFS
plugin that was developed against GeoServer 1.5 if you get interested in delivering
vector data for desktop GIS. With GeoServer it is not transactional and supports
only WFS 1.0, though.
-Jukka Rahkonen-
-----Original Message-----
From: geoserver-users-bounces@lists.sourceforge.net on behalf of diana2
Sent: Wed 31.10.2007 17:50
Subject: Re: [Geoserver-users] modify the shapefile's contour
Andrea,
Thanks
Diana
specification here
Hope this helps
Jukka , Andrea,
thanks for your response, I'll tried with your suggest. :slight_smile:
Best Regards
diana
aaime wrote:
diana2 ha scritto:
Andrea,
experimental
Unfortunately not.
View this message in context: http://www.nabble.com/modify-the-shapefile's-contour-tf4718770.html#a13513195
