On Sat, May 28, 2016 at 11:15 AM, Brad Hards <bradh@anonymised.com> wrote:
> one thing I've noticed is that we're lacking a mongodb plugin for
geoserver, we probably
> need to make a release descriptor for it in community land (assuming we
don't need to write
> a special store UI of course).
Since this would be a community module, these two would be probably
mandatory or highly
recommended:
- changes to the release (nightly module)
- testing and fixes (at least the namespace part which does not appear to
be editable).
and these two (very) nices to have:
- documentation for the geotools module (ideally)
- documentation for the Geoserver part
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
